Wine barrel stave - how to smooth out internal surface
Forum topic by Foozin01 posted 09-25-2018 01:43 AM 278 views 0 times favorited 3 replies Add to Favorites Watch
View Foozin01's profile
Foozin01
1 post in 77 days
09-25-2018 01:43 AM
Topic tags/keywords: stave
First off, I am new to this site and relatively new to woodworking.
Need some ideas on how to smooth down the inner surface of The Stave, see attached image.
For the record, the inside of the stave bows in on both the width and obviously the length.
Trying to make the following.
Thanks for your help!!!
3 replies so far
View John Smith's profile
John Smith
1481 posts in 360 days
#1 posted 09-25-2018 02:01 AM
to keep it authentic, you need to leave all the flaws and burned wood in tact and clear over it.
to remove all the remnants of being hand made, you then have just another bent board.
if it is not charred on the inside, I would use a bottle torch and burn it a little.
(pour some Jack Daniels over it to give it a little character).
-- I started out with nothing in life ~ and still have most of it left.
View lumbering_on's profile
lumbering_on
574 posts in 688 days
#2 posted 09-25-2018 02:29 AM
- John Smith
I agree with John about keeping the flaws
That being said, if you do want to smooth it, there are three options I’m aware of
1) a curved hand plane – Stanley makes one, they are hard to obtain, and probably harder to use. I’ve never used it, but I had an instructor that could, and he’s wasn’t exactly singing the praises of it.
2) a curved card scrapper
3) a sanding mop
Good luck.
View EdDantes's profile
EdDantes
40 posts in 108 days
#3 posted 09-25-2018 02:49 AM
Agree on the fact that smoothing it would lead to it losing the character…then what’s the point? At most I’d use sanding mops to get it “smooth” while leaving the character. Also it appears the picture you’re trying to replicate was perhaps a wine barrel stave given its burgundy color. You could certainly mess around with some water-based dyes (e.g. TransTint) to get that look.
If you were really looking to smooth it out I’d use a draw knife followed by sanding or a round-bottom spokeshave. The latter is not only harder to use, but also something that won’t get much use for the majority of people.
