Template Routing
Forum topic by EdsCustomWoodCrafts posted 09-23-2018 07:42 PM 593 views 0 times favorited 6 replies Add to Favorites Watch
View EdsCustomWoodCrafts's profile
EdsCustomWoodCrafts
864 posts in 1544 days
09-23-2018 07:42 PM
Hi everyone and hope you are having pleasant Sunday.
So a little about the project and then the question …
I am making a sharpening station and I want to recess out the top to receive my sharpening stones so they don’t move around . I need to recess 5 (3” x 8”) sections that are 3/4” away from each other.
Tools being used:
A Bosch plunge router and template guide bushing set
Question:
Can I use a straight router bit because the spiral bit I have will not protrude deep enough into the workpiece ? The reason I am asking is because I have 2 1/2” straight router bit and my spiral bit is only 2” long and doesn’t protrude beyond the template guide and I am using the shallowest bushing that I have
Thanks
Ed
-- Thanks Ed “A bad day woodworking is better than a good day working. ~Author unknown”
View Bill White's profile
Bill White
5124 posts in 4161 days
#1 posted 09-23-2018 08:56 PM
Yes you can use a straight bit. Just remember that you’re not building fine furniture. It is a sharpening station.
Clean up the corners and get to sharpening.
You did not state what wood you’ll be using.
-- bill@magraphics.us
View jerryminer's profile
jerryminer
944 posts in 1642 days
#2 posted 09-23-2018 09:34 PM
A 2-inch bit doesn’t extend beyond the template bushing? I think you’re not getting the full-depth plunge from your router.
But, yes, a straight bit will do it. How deep are you trying to go? A very shallow recess will keep the stones from sliding around (a cleat on top of the surface might be easier to do and make it easier to clean up the sharpening sludge)
EdsCustomWoodCrafts
#3 posted 09-23-2018 11:11 PM
A 2-inch bit doesn t extend beyond the template bushing? I think you re not getting the full-depth plunge from your router.
- jerryminer
You may be right I need to check, I tkiught about a cleat but thought it would be cool to try recessing as I have never done it before… I’m hiding a scrap piece of oak I have lying around . As for the depth probably less than 1/4” deep
EdsCustomWoodCrafts
#4 posted 09-23-2018 11:12 PM
Yes you can use a straight bit. Just remember that you re not building fine furniture. It is a sharpening station.
You did not state what wood you ll be using.
- Bill White
I’m using a scrap piece of 4/4 red oak I had lying around
View Kirk650's profile
Kirk650
576 posts in 949 days
#5 posted 09-24-2018 02:12 AM
I use an MDF ‘board’ with cleats to hold the stones (diamond plates, in my case). Works great, but getting nasty looking after a few years.
EdsCustomWoodCrafts
#6 posted 09-24-2018 03:58 AM
- Kirk650
I am using a solid oak panel that also sits on cleats and if it gets all dinged up I’ll just remake the top
Here is a picture with the frame glued up
