entry level vacuum laminating setup
Forum topic by dbouch posted 09-23-2018 05:32 PM 536 views 0 times favorited 4 replies Add to Favorites Watch
View dbouch's profile
dbouch
8 posts in 537 days
09-23-2018 05:32 PM
i’m interested in putting together an entry level vacuum pump/bag setup. i have no experience with this at all. i’m assuming i’ll need a pump and bags, but have no idea about anything else i might need – ie. valves, correct tubing etc.
i’ve checked the woodcraft, rockler, grizzly catalogs and only one system shows up for $1400 or so. i’m hoping some body here with experience can recommend a beginning system that i can put together for a lot less than that.
thanks in advance….
D
View jbay's profile
jbay
2858 posts in 1096 days
#1 posted 09-23-2018 05:44 PM
Here is your guy.
https://www.joewoodworker.com/veneering/welcome.htm
You can call him, he is a lot of help.
View CaptainKlutz's profile
CaptainKlutz
596 posts in 1691 days
#2 posted 09-23-2018 09:32 PM
Joe Woodworker site posted above is great resource. :)
FWIW:
There is another industry that heavily uses vacuum bag for creating laminated parts: fiberglass and epoxy resin Composites. Everything from aerospace parts, marine hulls, and surfboards use vacuum bagging processes.
For absolute beginner; investment into universal, large size, reusable plastic bag and system for veneer work can be scary. When you start out, not sure what you might eventually need?
There is a solution:
Composites folks make mostly odd shaped parts and use much thinner disposable bag materials, breather ply for odd shapes, and heavy tape to seal bags. Using disposable materials for your first project will be much cheaper than what wood working stores want you to believe.
Here is what I call the ‘back yard’ vacuum bag supplies list:
Get a single stage vacuum pump from HF for <$80 with coupon, buy a plastic thru bag connector for $5, proper sized vinyl tubing, ball valves and brass fittings (BORG or Ace Hardware), use 2-3mil polyethylene or nylon plastic film (BORG or ACE hardware), and Gorilla Brand duct tape to seal bag; now you will be ready for your 1st vacuum bag project for less than $150.
Must add that if you intend to produce a lot of veneer panels, using disposable materials will be more expensive in long run. If you want to create a permanent veneering station in your shop, that you should invest in a heavy reusable 20-30 mil bag, reusable closures, and upgraded flat bag connector; I.E follow advice Joe Woodworker site or wood working magazines recommend for bag materials. :)
Here are some WWW sites that offer vacuum bag supplies for composites market:
https://www.fibreglast.com/category/Vacuum_Bagging
[Have worked with fiberglast folks for 25+ years. They like to help the DIY folks.]
http://uscomposites.com/vacuum.html
http://www.fiberglasssupply.com/Product_Catalog/Vacuum_Bagging/vacuum_bagging.html
https://www.rockwestcomposites.com/materials-tools/vacuum-bagging-materials
There are many more sources of information and supplies if ask Google for help.
View AandCstyle's profile
AandCstyle
3177 posts in 2454 days
#3 posted 09-24-2018 09:30 PM
+1 on Joewoodworker. His site has a wealth of info.
-- Art
dbouch
8 posts in 537 days
#4 posted 09-25-2018 03:08 PM
it’s a start. thanks for the input.
d
