Question about bolt holes on Craftsman Radial Arm saw front table build.
Forum topic by newparade posted 09-23-2018 12:50 PM 253 views 0 times favorited 4 replies Add to Favorites Watch
View newparade's profile
newparade
5 posts in 38 days
09-23-2018 12:50 PM
Topic tags/keywords: question ras craftsman radial arm saw table
Hi,
I am building a front table for a Craftsman RAS Model 113.19770. I don’t have the old table. While I can copy the hole placement for the table bolts from the mounting frame and I have table dimensions, I am unsure how far away from the fence edge to place the bolt hole pattern (or if it even makes a huge difference).
Hopefully I have managed to correctly post a diagram here. In the circle, how far away is the fence from the center of the hole?
I appreciate your time. Thank you!
-- Scott, Southern Illinois
View Bill White's profile
Bill White
5072 posts in 4109 days
#1 posted 09-23-2018 01:26 PM
The table set is relative to the fence. The blade should just clear the back of the fence, so the table should be set to allow that clearance. Kinda be a “work from the back side” design. Some RAS users will also swap the fence to the rear of the clearance board (the board to the rear of the fence) to allow for wider rip cuts.
-- bill@magraphics.us
View WhyMe's profile
WhyMe
1053 posts in 1710 days
#2 posted 09-23-2018 01:47 PM
I have that saw and the hole center is 1-3/8” from the back edge of the front top section.
View ocean's profile
ocean
107 posts in 982 days
#3 posted 09-23-2018 02:37 PM
My father had that saw and I remember that there were holes in the frame below (4) that is the base of the saw. They were designed so that you could place all your bolts thru the top and then thru the hole in frame. Slots were wider on one end and narrow on the other end to catch the bolt head. You then tighten from above on the top to lock in place.
-- Bob, FL Keys
newparade
5 posts in 38 days
#4 posted 09-24-2018 04:53 AM
My sincere thanks to you guys.
