SawStop table came out of square.
Forum topic by Alan72 posted 09-23-2018 02:46 AM 523 views 0 times favorited 9 replies Add to Favorites Watch
View Alan72's profile
Alan72
216 posts in 2236 days
09-23-2018 02:46 AM
Little over a year ago I was using my saw with my tening jig and the jig nicked the blade which activated the Brake . Every since that occurred I noticed that it was little harder to push material. I would feed the material, halfway through the saw blade, it felt like it was being pinched against the fence. I adjusted the fence kicking it out to the right at the top the table but it did the same thing. This past weekend I was using the saw and switched to the original insert plate and noticed the saw was rubbing against it. I pulled out my manual and proceeded to go through the steps aligning table to the blade. It wasn’t too bad, I adjusted it to insert plate and it worked just perfect. My question is to those who own these saw and If you set off your brake off did your table come out of alignment.
9 replies so far
View therealSteveN's profile
therealSteveN
1714 posts in 777 days
#1 posted 09-23-2018 03:22 AM
Only because you said it started after triggering the safety…........
Page 45 have you done everything they tell you to do after triggering the safety?
If none of that worked I’d call Steve Gass at home.
-- Think safe, be safe
View Redoak49's profile
Redoak49
3669 posts in 2192 days
#2 posted 09-23-2018 11:38 AM
No…my table was fine after a brake activation.
View clin's profile
clin
956 posts in 1199 days
#3 posted 09-23-2018 03:58 PM
I’ve triggered mine once and nothing changed.
-- Clin
View TheFridge's profile
TheFridge
10747 posts in 1689 days
#4 posted 09-23-2018 04:03 PM
Square it up and put it back to work. Even if the brake knocked it out of alignment I’d still lump it in with maintence that has to be done every now and again.
View johnstoneb's profile
johnstoneb
3063 posts in 2376 days
#5 posted 09-23-2018 04:16 PM
I’ve tripped mine no problems afterward.
-- Bruce, Boise, ID
View fly2low's profile
fly2low
55 posts in 300 days
#6 posted 09-23-2018 06:56 PM
I’ve tripped mine without consequences
-- Rich Gig Harbor, WA
Alan72
#7 posted 09-23-2018 07:57 PM
Thanks to everyone who replied, I am just glad the saw is up and running the way it was prior to the brake going off. .
View Alex Lane's profile
Alex Lane
541 posts in 4093 days
#8 posted 09-23-2018 07:58 PM
Same. A coworker inadvertently touched the blade with a vise grip squeeze clamp. Haven’t checked the alignment on the SS after it triggered, but haven’t noticed any problems yet. Mainly used for precise edge ripping of biplane wing spars with a 7 to 14° bevel angle, and haven’t noticed it out of alignment…with the fence at least. Very rarely even use the miter slot :)
-- Lane Custom Guitars and Basses
View mramseyISU's profile
mramseyISU
555 posts in 1749 days
#9 posted 09-24-2018 01:15 PM
- TheFridge
I don’t have a sawstop (yet) but I check the alignment on my saw once a year. I get a week shutdown at Christmas time every year and do that along with a bunch of other maintenance in my shop.
-- Trust me I'm an engineer.
