need advice about walnut
« back to Woodturning forum
Forum topic by Karda posted 09-23-2018 02:19 AM 483 views 0 times favorited 8 replies Add to Favorites Watch
View Karda's profile
Karda
1286 posts in 700 days
09-23-2018 02:19 AM
Hi, I have been turning black walnut lately and have been having a terrible time with tear out.Its seems that walnut is prone to tear out is this true. remembering back I can’t think of a species of wood that I have turned that has had that much tear out and its deep. Any suggestions thanks mike
8 replies so far
View therealSteveN's profile
therealSteveN
1410 posts in 720 days
#1 posted 09-23-2018 03:17 AM
Hi Mike
Shallower cuts, and sharper tools. Walnut like a lot of woods can have a fairly open grain, and it if you go deep, especially with a tool in need of sharpening like a lot of woods, you’ll be seeing some chunks. Get after those, and they quickly become ragged chunks.
-- Think safe, be safe
Karda
#2 posted 09-23-2018 03:24 AM
ok thanks
View Wildwood's profile
Wildwood
2425 posts in 2281 days
#3 posted 09-23-2018 01:48 PM
Know you don’t like watching videos but this DVD to have and review worth your attention. If can find Bowl Turning With Del Stubbs DVD normally less than $20 in your area buy it. Was my first VCR tape on woodturning ever bought.
Here is a short sample: https://www.youtube.com/watch?v=kbijBCos62E
This guy makes everything about bowl turning so easy to understand! Yes it is old but nothing really changed about turning bowls.
Little backgtound on the guy:
https://americanart.si.edu/artist/del-stubbs-27956
No longer a professional woodturner, has a knife making business.
http://pinewoodforge.com/
-- Bill
View LeeMills's profile
LeeMills
600 posts in 1447 days
#4 posted 09-23-2018 01:53 PM
Other than already mentioned maybe the same as punky wood.
Turn close to the shape then start coating with a sanding sealer to harden the wood. I use 1 part shellac to 2 parts DNA. Dries fairly quickly. You will probably need to add new sealer at least every 1/8 -1/4” removed.
Karda
#5 posted 09-23-2018 09:14 PM
Thanks for the del Stubbs links I’ll see what I can find, any suggestion where I might find his videos. Any on utube.. Lee the wood isn’t punky this happens with all the walnut I have turned from several different trees. Other wood i get tear out but not as bad that why I thought it might be a quirk of the wood
View TheFridge's profile
TheFridge
10334 posts in 1632 days
#6 posted 09-23-2018 09:49 PM
I don’t turn much but when I do the shavings just fly off. Bevel always in contact with the wood.
Do you have shavings or dust? What does the surface look like? Poor?
Karda
#7 posted 09-24-2018 12:09 AM
I have a little of both, I think I am getting better at sharpening, maybe things cut better sometimes but I still get a lot of tear out
View Kirk650's profile
Kirk650
566 posts in 895 days
#8 posted 09-24-2018 02:07 AM
I’d guess the problem is that the tools aren’t sharp enough. After all these years of turning this and that, I can tell when it’s time to walk to the bench grinder. There’s a Veritas tool rest on it, which is infinitely variable on angles of sharpening. I can sharpen a dull gouge in 30 seconds. Takes longer to find the angle on a scraper.
