Best way to rout stopped sliding dovetails
Forum topic by groland posted 09-22-2018 06:44 AM 1404 views 0 times favorited 22 replies Add to Favorites Watch
View groland's profile
groland
202 posts in 3558 days
09-22-2018 06:44 AM
Topic tags/keywords: best way to rout stopped sliding dovetails
I want to use sliding dovetails to make some drawers. If I want to make the drawer sides shorter than the fronts, I will need to stop the dovetails in the drawer fronts before they come all the way through.
I have not used dovetail bits before. What is the best, safest, way to do this?
Thanks
22 replies so far
View GR8HUNTER's profile
GR8HUNTER
4725 posts in 858 days
#1 posted 09-22-2018 02:10 PM
rout dovetails first then install Drawer fronts :<))
View Rich's profile
Rich
3661 posts in 735 days
#2 posted 09-22-2018 02:18 PM
It’s easiest if you cut a stopped dado first, then cut the dovetail. That way there’s less material to remove. The sides are easy, just sneak up on your fit.
The tricky part will be that you are working on the narrow end of the drawer front and sides. You’ll need some way to stabilize the cut. Since I have no idea what tools you are using, I can’t help you there.
View waho6o9's profile (online now)
waho6o9
8422 posts in 2723 days
#3 posted 09-22-2018 02:26 PM
^ Yeppers
1-Dado
2-Dovetail
Whiteside router bits work well.
View BlasterStumps's profile
BlasterStumps
895 posts in 585 days
#4 posted 09-22-2018 02:32 PM
When I do something like this, I do it on trial pieces that are the same dimensions as the piece that I want to use in the project. Test, test, test. You will find out quickly what works and what doesn’t.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View bondogaposis's profile
bondogaposis
4991 posts in 2497 days
#5 posted 09-22-2018 02:45 PM
I’m not sure why you want to do this as they will be prone to sticking in humid weather, unless you make them really loose, which sort of defeats the purpose. A dado will work just as well and be a lot easier to fit. But if you have to do it, it is best done on a router table, hog out most of the waste with a straight bit, then clean up with a dovetail bit.
-- Bondo Gaposis
View Aj2's profile (online now)
Aj2
1722 posts in 1944 days
#6 posted 09-22-2018 05:09 PM
You can add the slide below the drawer bottom or if you like to challenge yourself incorporate it with the drawer bottom. Either way pick your wood carefully if you get too much warping the sliding action is sticky like Bondo mentions.
I find drawer making very rewarding but I hardly ever get to do it.
-- Aj
View Rich's profile
Rich
#7 posted 09-22-2018 05:26 PM
Aj, Bondo, I think he’s referring to using sliding dovetails to attach the drawer fronts to the sides, not as drawer slides.
View AlaskaGuy's profile
AlaskaGuy
4508 posts in 2455 days
#8 posted 09-22-2018 05:55 PM
Aj, Bondo, I think he s referring to using sliding dovetails to attach the drawer fronts to the sides, not as drawer slides.
- Rich
That’s what I think also. Used to be a common what to attach factory made drawer fronts. Still might be haven’t noticed in a long time. Not sure but it seems like that method was used of the contractor grade cabinets. I’m sure Youtube will have a video of this.
https://www.youtube.com/results?search_query=sliding+stopped+dovetails+for+drawer+fronts
AlaskaGuy
#9 posted 09-22-2018 06:08 PM
Didn’t find a really good video (yet anyway) but I found this. +1 on what Rich said too.
https://www.wwgoa.com/article/making-sliding-dovetails/
View jbay's profile
jbay
2677 posts in 1045 days
#10 posted 09-22-2018 06:36 PM
I use my panel router. Makes quick work on rights or lefts, just set the stops and go.
You could easily make a router sled that your router slides on, and move your front from side to side.
Aj2
#11 posted 09-22-2018 07:54 PM
Thanks Rich your right. Why someone would want to do that is beyond me. I’m stepping out of this thread…..
-- Aj
View WoodenDreams's profile
WoodenDreams
127 posts in 57 days
#12 posted 09-22-2018 08:04 PM
Have you thought of dado cutting the slides and wax the sliding surface. It’s just easier than dovetailing the slides. Less worry of expansion and binding. If your thinking dovetail on the drawer face, great and looks nice, but more work. Finger joints easier and There are router bits for drawer joints using with a router table.
View jbay's profile
jbay
#13 posted 09-22-2018 09:49 PM
View Rich's profile
Rich
#14 posted 09-22-2018 10:01 PM
What? Not animated?
- jbay
AlaskaGuy
#15 posted 09-22-2018 10:13 PM
- Aj2
Agree with that.
