| Forum topic by sIKE | posted 602 days ago | 822 views | 0 times favorited | 8 replies | ![]() |
602 days ago |
I have a Norton Coarse Crystalon Sharpening Stone that I use for grinding my blades. I noticed towards the end of my grinding session (3 Plane blades and 12 Chisels) that I blades were getting a bit concaved. I then knew that it was time to flatten the stone again. Honestly I have not flatten it since I got it. So out came my coarse diamond stone. Now here is the question after a couple minutes of rubbing the stones together I could clear see the dish in the stone. After a couple of more minutes of rubbing I can still see the same exact shaped dish. So is my diamond stone worn out or am I to impatient? When I have flattening do I need to add any oil or water? I got my first ‘bigger’ hand plane a #4 Smoothing plane by Groz (a cheapy one to learn with) and first off the blade came to me in bad shape(expected), and was a part (one of the longest to grind) of todays grinding session. My question is does the chip breaker need to be sharped or any other work need to be done with it? -- //FC - Round Rock, TX - "Experience is what you get just after you need it" |
