I want to build a boat!!!
Forum topic by HuntleyBill posted 08-06-2011 10:46 PM 3687 views 1 time favorited 22 replies Add to Favorites Watch
View HuntleyBill's profile
HuntleyBill
103 posts in 3090 days
08-06-2011 10:46 PM
Hello fellow Lumberjocks:
I am considering building a small wooden boat. Why? Because no one told me I couldn’t and because I have never done it! Two great reason. After some web research, I came accross the Minimost ( www.minimost.com ) This boat to me looks like a blast. Inexpensive to build and can be easily pulled behind my 1930 Ford Model A.
Looking through their website I found that some of the boat lumber is fir. During my last visit to my Big Box store, I asked if they had fir and the guy mentioned sure but it’s mixed in with the pine an spruce 2xX stock.
Being the wood novice that I am, I said to myself….self, is fir, spruce, pine all the same or very similar? Then I thaught, fir tree….pine tree. Then I started humming Christmas tunes but that’s another post!
So…I have two questions…
  • Is fir, pine etc. the same or VERY similar stuff?
  • Has ayone else built these or similar boats?
The posts on these forums have not been used since 2006-2007 so I don’t know if they are even active any more and I have a lot more question specific to the building of these kind of boats.
Looks like a fun project
-- If you think you can, or think you can't...your right!
22 replies so far
View samual's profile
samual
2 posts in 2485 days
#1 posted 08-06-2011 11:23 PM
Hey Huntley,
I believe that this article can help you decide:
http://www.smallboatplansreview.com/boat-building-tools-tips/what-is-the-best-wood-for-boat-building
good luck!
S
View SSMDad's profile
SSMDad
395 posts in 2596 days
#2 posted 08-07-2011 01:16 AM
Here’s the one I want… err… want to build! Lord Nelson’s Flagship at the Battle of Trafalgar!
Rule Britannia!
(yeah I want all 104 working guns too!!) Not asking too much is it? :)
-- Chris ~~Who controls the past controls the future. Who controls the present controls the past."
View David Kirtley's profile
David Kirtley
1286 posts in 2997 days
#3 posted 08-07-2011 02:44 AM
In this case, fir, pine or cedar could be used. Not much of a difference.
The techniques are pretty dated in comparison to modern plywood boat construction.
The plywood could be improved on. If available, I would go with a real marine plywood for longevity. Better plywood would also allow you to go thinner and lighter and still be stronger. At least baltic birch or other well sealed hardwood plywood with exterior glue. If you go with the fir ply, you will need to glass the whole thing because the fir ply will check.
Epoxy is easier to work with and more forgiving than Weldwood.
I would also add some enclosed flotation to have something to hang on to when that puppy goes airborne and comes back butter side down.
View rance's profile
rance
4258 posts in 3160 days
#4 posted 08-07-2011 04:20 AM
Bill, Hopefully ‘Shipwright’ here on LJ will chime in. He used to build boats. You might also contact ‘tyvekboy’ here on LJ. He uses tyvek for boatbuilding.
View Lee Barker's profile
Lee Barker
2170 posts in 2850 days
#5 posted 08-07-2011 07:35 AM
I have built the Nutshell Pram, a Joel White design. It was a successful outing. Not sexy like the hydroplane.
Boat plans are highly refined documents. You can mess with a table design, but unless you’re an expert, you’re wise to stay with the exact specs of a boat plan.
And if you’ve never built a boat before, and do, I suspect you’ll discover this interesting factoid: Everything else I’ve built has started from the wall or the floor. A boat starts at a point in space. Go for it!
Kindly,
HuntleyBill
#6 posted 08-07-2011 05:20 PM
Thank you all for your help. This design is decades old and thus the wood choice is dated. One of the many reasons I come to the experts. Yes…that’s YOU! If there is a better choice of wood, you guys would know it. I’ve had suggestions of luan instead of ply etc. I don’t know if that is viable or not.
Also, I wanted this boat to be able to accommodate 2 people. So I figured I would enlarge it from 8 feet to 10 feet and maybe go a little wider. So, if going from 8 to 10 feet is a 25% increase in length, does that mean I go 25% wider and deeper???? I’m beginning to realize why I don’t sleep well!
David Kirtley
#7 posted 08-07-2011 08:01 PM
Changing stuff is a slippery slope. You will always be plagued with adding more here and there.
Going from 8’ to 10’ introduces scarfing plywood. Not that hard to do but another skill to learn.
Lost of times people go length only for enlarging. It does sometimes change the bracing as well. For go fast boats, you have to be careful because you can make things that will trip up the boat and make it tend not turn well or safely.
Glen-L has similar designs that are bigger.
For your first one, I strongly suggest going from someone else’s plans and build to spec. Then start changing to your liking on the next ones. (There will be more. It is addictive.)
You want a go fast boat to carry more people and look good behind a model A, A Bolger Sneakeasy would be sexy.
SSMDad
#8 posted 08-08-2011 02:23 AM
Sorry Samual. It was supposed to be a joke. (though I really wouldn’t mind having it)
I’ve been interested in building a little boat too so I’m glad you asked this.
Cheers!
View helluvawreck's profile
helluvawreck
31096 posts in 2866 days
#9 posted 08-08-2011 03:15 PM
Building a boat is something that I have always wanted to do and I have two or three very good books on it that I have probably had for 20 years. However, at 61 and with more directions that I would like to take up in woodworking it is doubtful that I will ever build one. I say go ahead and build one while you can. It may be the only opportunity that you will ever have.
View crank49's profile
crank49
4030 posts in 2970 days
#10 posted 08-08-2011 03:38 PM
I can remember that design from when I was just becoming an engineer. I wanted to built that very boat; even got plans, I believe. I changed my mind whan I saw one flip and land “butter side down” on Wheeler Lake.Those things are very finicky, almost low flying airplanes. I wouldn’t dream of getting away from the original design at all; except to use more modern materials.
HuntleyBill
#11 posted 08-08-2011 03:52 PM
Ok Ok…you talked me out of that boat. I’m now looking at the Glen-L TNT design. 11 foot and built for 2 with a little extra room for the dog!
Then there was the suggestion of instead of an outboard, use a jet ski motor and pump! I love it! hmmmmm 750 cc, 1000, 1200????? decisions decisions.
I’m going to have to name the boat after Lumberjocks for all the good help and advice. There is another idea…a naming contest!!
David Kirtley
#12 posted 08-08-2011 05:28 PM
If you look at the inboard ones, they have the 11’ Dyno Jet already designed for powering with jetski propulsion.
View shipwright's profile
shipwright
7980 posts in 2797 days
#13 posted 08-09-2011 03:07 AM
I hope you do build, Bill.
My advice for anyone in your position (as per my PM to you) would be to seek out plans from a respected designer who specializes in designs for, or at least caters to novice builders. They will give you lots of info that most designers assume that the builder already knows.
Glen-L is certainly in that group.
View Dan Lyke's profile
Dan Lyke
1520 posts in 4125 days
#14 posted 08-09-2011 08:20 PM
I’m gonna go the other way on this one. This spring I competed for the first time in the Bodega Bay Fisherman’s Festival Boat Building Competition. 2 sheets of 3/8” ply, a couple o’ 2×2s, a stack of 1×2s, a sheet of plastic, a pound of 1” wood screws, a pound of nails, a few tubes of caulk, a few other things.
Add 4 people on your team, 3 hours, battery powered drill drivers and hand tools. And then you race.
My takeaway from all of this is that you can build a nice little paddleable boat that’ll last you for a summer for $30 and an afternoon.
Pictures from our build (follow the link on the bottom to go further).
That basic experience taught me a lot about boats and boat building, the value of plans, but mostly the value of saying “yeah, this afternoon I’m going to build a boat”.
rance
#15 posted 08-13-2011 01:06 AM
Dan, I have to admit, that there looks like a LOT of fun. A nice Father/Son project. Or a Father/Daughter project. Now the determining question to Bill is “How long do you want your boat to last?”.
