Whiskey Barrel Top/Bottom Glue Recommendations
Forum topic by Ivan posted 08-06-2011 10:14 PM 4422 views 0 times favorited 7 replies Add to Favorites Watch
View Ivan 's profile
Ivan
185 posts in 3618 days
08-06-2011 10:14 PM
Hey all,
I have a good friend who was asking me about making him some whiskey barrels from White Oak.
I was going to do a test run just making cylinders, but am concerned about what type of glue would be acceptable for making the circular top/bottoms. I want to avoid a glue that alcohol will dissolve or extract any type of flavors.
What is typically used for gluing up boards to make the top/bottom??
-Ivan
-- "Do it right the first time, you'll just kick yourself later..."
7 replies so far
View hObOmOnk's profile
hObOmOnk
1381 posts in 4369 days
#1 posted 08-06-2011 10:25 PM
No glue is used in making white oak whiskey barrel heads. We use only pegs and sometimes a little reed caulking. Once wet, the pieces will swell together.
About 800,000 barrels are made annually here in Kentucky.
-- 温故知新
View chrisstef's profile
chrisstef
17803 posts in 3247 days
#2 posted 08-06-2011 10:25 PM
If they are intending to use them for alcohol glue would probably be out of the question, i would guess. There is a particular process using steam which allows the boards to shrink and swell creating a mostly water tight cylinder .. i have no idea how to make one but i just saw a jim beam factory tour on TV and thats how they made the barrells.
Ivan
#3 posted 08-06-2011 11:46 PM
Would kiln dried oak be ok?
Simple pegs with no glue will hold them together enough until they get wet??
View adaughhetee's profile
adaughhetee
104 posts in 2924 days
#4 posted 08-07-2011 03:02 AM
What I saw on t.v. was they took the staves that were different widths and matched them up into a circle. They then took cherry red steel rings and drove them down tight. When they cooled they tighten up even more. I believe that was the version I saw on “how it’s made”. Here is a link for Jim Bean barrels which also talks about the steaming. http://www.youtube.com/watch?v=dkc6VzuQKco
View Richard's profile
Richard
1922 posts in 2931 days
#5 posted 08-07-2011 07:45 PM
I would think you could just buy them cheaper and a lot less work. do a google search for them.
hObOmOnk
#6 posted 08-07-2011 08:46 PM
Kentucky Barrels
-- 温故知新
View tbone's profile
tbone
276 posts in 3925 days
#7 posted 08-10-2011 05:58 PM
I’m not sure if anyone has answered your question yet. I think you’re asking about ONLY the heads that will be used at each end of the barrel, where you will likely have to edge-fit a few boards to get the width you need.
I think that the are just cut to fit tightly together, and dowels hold them in place. No glue.
-- Kinky Friedman: "The first thing I'll do if I'm elected is demand a recount."
