Zero clearance insert for the Grizzly G0771Z table saw
Forum topic by redan posted 09-18-2018 09:22 PM 275 views 0 times favorited 9 replies Add to Favorites Watch
View redan's profile
redan
4 posts in 84 days
09-18-2018 09:22 PM
Recently purchased inserts from grizzly not to my liking. The original inserts are attached by a clip on the back end and a magnet on the front end. There are five adjusting screws to bring it up to table height. The zero clearance insert has no clip and doesn’t have any metal for the magnet to hold. The five screws must be used to hold it in place after you shim the insert to table height. This is ok if you never want to use your dado stack or change the blade. Otherwise you must unscrew rather than just lift it off. Any ideas out there ????
9 replies so far
View RDan's profile
RDan
86 posts in 2522 days
#1 posted 09-18-2018 10:49 PM
Can’t say, I have the infinity insert on my Sawstop. Insert for each blade. Love the system. Dan
View ccc118's profile
ccc118
17 posts in 373 days
#2 posted 09-18-2018 10:54 PM
I don’t have the Grizzly one, but I have one made by Leecraft, which I think works really well. It doesn’t have a clip or magnet, but instead has two screws toward the front that are supposed to be backed out until you get a friction fit. This holds it in quite well. Are you sure there are no screws on yours anywhere that are supposed to provide a friction fit? It doesn’t seem right that you would have to use the leveling screws to secure it, as they are supposed to be underneath the insert and just raised or lowered by reaching through the holes with a screwdriver to adjust. If you use them to secure the insert, then you have no way to level it.
View GR8HUNTER's profile
GR8HUNTER
5099 posts in 911 days
#3 posted 09-19-2018 12:05 AM
I just put one in today mine had clip in front and also a screw to help make friction fit the magnet you must glue on and the 4 screws are just for leveling the insert :<))
redan
4 posts in 84 days
#4 posted 09-19-2018 10:33 AM
Yes gr8hunter the inserts that came with my saw can b leveled up by adjusting the screws by going through the holes. There’s a clip in the rear and since it’s metal the magnet recessed in the table holds down the front. The zero clearance insert is made from phenolic with no clip. The holes are countersunk in it for the screws. If you use the screws for leveling the insert comes out to easy. A safety hazard to me
redan
4 posts in 84 days
#5 posted 09-19-2018 10:40 AM
You have me wondering gr8hunter. Do you have a G0771z ? If you do I’m beginning to think they sent me the wrong ones.
redan
4 posts in 84 days
#6 posted 09-19-2018 10:45 AM
No ccc118 It has no screws in it. It’s made from phenolic. The top of the screw holes are counter sunk. This makes you think that it’s intended to b held in by the screws. Starting to think they sent the wrong insert for my saw
ccc118
#7 posted 09-19-2018 11:33 AM
Mine’s phenolic also, but has these screws at the front to provide a snug fit.
Mine isn’t the Grizzly one however. If you don’t anything like those screws, I would call them about it.
View Planeman40's profile
Planeman40
1307 posts in 2959 days
#8 posted 09-19-2018 01:57 PM
Just make one to your liking from wood. Or make two of them, one for your saw blade, one for your dado blade. Or even make one from aluminum. I have a 12” Hammer sliding table saw which has a narrow odd shaped saw blade hole. I made a zero clearance insert from aluminum plate. A wood cutting bandsaw will easily cut aluminum and a carbide tipped table saw blade will too. Just fit the aluminum insert into the hole, slide the saw fence over the insert but where it will miss the saw blade, and then slowly crank the saw blade up through the aluminum plate insert to cut the slot. Works like a charm! P.S. You can order almost any thickness of aluminum plate in small amounts from Online Metals https://www.onlinemetals.com/
GR8HUNTER
#9 posted 09-19-2018 02:42 PM
I have G0715P I have to take a picture I guess
