Using a Craftsman 113 top as a wing for a 315 saw?
Forum topic by Tedstor posted 09-18-2018 01:04 PM 192 views 0 times favorited 3 replies Add to Favorites Watch
View Tedstor's profile
Tedstor
1678 posts in 2779 days
09-18-2018 01:04 PM
So I’ve been busy reviving my 315 (113) series Craftsman Table saw over the past couple weeks. I currently have a cast iron ‘webbed wing’ and a stamped steel wing installed. They both SUCK. I’d love a cast wing.
Is there any reason I couldn’t buy an old 113 off craigslist for a few bucks, strip off the top, and install it on the 315 as a wing? The mounting holes ‘should’ line up- no? I would probably actually cut the top in half(ish) from top to bottom as I don’t need a wing that big, and that much weight might make the saw unstable.
Any thoughts?
3 replies so far
View jonah's profile
jonah
1841 posts in 3445 days
#1 posted 09-18-2018 03:01 PM
It could work, but the holes may not line up. That’s not a huge issue, however, since cast iron is quite easy to drill holes in. Just drill some new holes and bolt it on.
You’d be better off if you have a pretty beefy fence/rail combination, since the angle steel from the fence rails will help hold everything together. If you have the OEM fence, you might end up with a lot of sag.
View mathguy1981's profile
mathguy1981
39 posts in 51 days
#2 posted 09-18-2018 05:36 PM
That should work. I have purchased a few extension wings off of ebay, you just have to get lucky and find solid ones that don’t cost a fortune. I got lucky once and scored two wings for about $30 and then $50 for shipping.
More recently I put an ebay Craftsman wing on the right side of my Grizzly and it bolted right up, no drilling. (I have the G0651 and I substituted part of the MDF right extension for cast iron)
View uptoolateman's profile
uptoolateman
43 posts in 217 days
#3 posted 09-18-2018 11:09 PM
Have you thought about installing a cast iron wing with a router table cut out like the benchdog or MLCS? It’s a pricey upgrade, but a good one if you have limited space. I was lucky with my 315 saw it had a solid cast iron wing on one side with a router mount and a stamped wing on the other that I replaced with the Benchdog, I now have 2 routers mounted on my saw. I’ve also seen where people filled in the webs of the standard CI wing with wood.
