Why Won't My Planes Work On Hardwood?
« back to Hand Tools forum
Forum topic by SleepingFox posted 09-18-2018 12:49 AM 962 views 0 times favorited 26 replies Add to Favorites Watch
View SleepingFox's profile
SleepingFox
8 posts in 131 days
09-18-2018 12:49 AM
Topic tags/keywords: question plane
Hello,
I’m new to the woodworking craft and have picked up a pair of used hand planes. I’ve tuned them up and sharpened the blades and they work beautifully on any softwood. I’ve tried them on Fir, Pine and Cedar all with great success. However as soon as I try and run them over some hardwood they skip and stop and make atrocious marks all over the wood. I’ve tried on Cherry, Maple and White Oak and the planes are hopeless on all of them.
Can anyone tell me what I might be doing wrong or if I just need newer, better planes. Also if pictures or more information would help just let me know what you need and I’ll post it.
Thanks for the help
26 replies so far
View Mr_Pink's profile
Mr_Pink
136 posts in 572 days
#1 posted 09-18-2018 12:53 AM
Have you tried taking a lighter cut? What happens if you back the iron up so it won’t cut, and then slowly advance the iron until it just barely cuts?
View bandit571's profile
bandit571
21753 posts in 2883 days
#2 posted 09-18-2018 01:14 AM
And…don’t go against the grain….
SleepingFox
8 posts in 131 days
#3 posted 09-18-2018 01:19 AM
Have you tried taking a lighter cut? What happens if you back the iron up so it won t cut, and then slowly advance the iron until it just barely cuts?
- Mr_Pink
This seems to have helped but I’m not sure if it has completely fixed the problem. I can now get the plane to slide across the wood without skipping however what I end up taking off is more like sawdust than shavings. I’ll keep messing around and give them both a fresh sharpen to see if I can get this sorted.
View BlasterStumps's profile
BlasterStumps
982 posts in 639 days
#4 posted 09-18-2018 01:52 AM
My eyes are not so good so I made a “grain direction detector” to help me find grain direction. I asked my wife for a piece of nylon stocking. I rolled it into a ball and stuck it in the end of a piece of wood dowel. When I want to see which direction the grain is going on a piece of wood, I simply rub the nylon along an edge. It will catch on the fibers sticking up when rubbed against them. Works pretty good. Saves digging up the fibers with the plane for the most part.
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
Smitty_Cabinetshop
15694 posts in 2818 days
#5 posted 09-18-2018 02:04 AM
‘Sharp’ that fails against hardwood ain’t sharp. Harsh reality, and one huge reason I love working with pine. Lawl.
View JayT's profile
JayT
5960 posts in 2411 days
#6 posted 09-18-2018 02:20 AM
- SleepingFox
That’s a sure sign of not being truly sharp.
View shampeon's profile
shampeon
1883 posts in 2383 days
#7 posted 09-18-2018 02:33 AM
+1 to all the others saying, “not sharp enough.”
How are you sharpening the blades? Sandpaper, stones, something else? Any of the various ways works, so choose one and work on getting the back of your blades flat, an even bevel, a wire burr at each grit before moving on, and a strop to get it mirror sharp.
If you’re looking for a simple and reliable sharpening method, look up Paul Seller’s videos on sharpening.
View QuangFromCalgary's profile
QuangFromCalgary
35 posts in 3198 days
#8 posted 09-18-2018 03:51 AM
If it produces something like saw dust, then I am pretty sure it is not sharp enough. That happened to me too when I started. Please do the sharpening again. Then take very light shave at beginning, go with the grain. I believe you will find the magic of shaving the wood by hand plan. It is addictive…. :)
Good luck.
View Planeman40's profile
Planeman40
1307 posts in 2961 days
#9 posted 09-18-2018 08:37 PM
Two hints.
1. When sharpening, periodically take a close look at the edge under magnification. A cheap 10X (10power) jeweler’s loupe for around $5 to $7 should do the job. This will enable you to REALLY see what you are doing to the edge. Very educational!
2. Try taking a SLICING cut with your plane by holding it at a slight angle to the work when planing, roughly 30 degree angle or so.
View HokieKen's profile (online now)
HokieKen
7075 posts in 1338 days
#10 posted 09-18-2018 08:47 PM
Don’t take this the wrong way but, your blades aren’t upside down are they? :-) Just gotta check… you wouldn’t be the first. Make sure your bevel is down (assuming BD planes…)
If not, then yup. Sharpen them suckers up some more.
-- Kenny, SW VA, Go Hokies!!!
View corelz125's profile
corelz125
566 posts in 1176 days
#11 posted 09-18-2018 09:11 PM
you know its sharp enough when you shave the hair right off of your arm
Smitty_Cabinetshop
#12 posted 09-18-2018 09:15 PM
Sleepingfox ain’t regarding any of this, apparently. Oh well, good advice nonetheless.
View RPhillips's profile
RPhillips
1238 posts in 2036 days
#13 posted 09-18-2018 09:27 PM
Blaster, Nice tip on the stocking! I may be utilizing that myself as I still have a difficult time identifying grain direction.
SleepingFox, Google “Scary Sharp” sharpening technique… as everyone mentioned, you ain’t sharp yet!
-- Rob - Indianapolis IN - Learning... one mistake at a time...
Planeman40
#14 posted 09-18-2018 09:40 PM
That’s true corelz125! That is the ultimate test and the one I always use.. I made a set of 62 wood carving gouges a couple of years ago (http://lumberjocks.com/Planeman40/projects) and the final test on each one was shaving the hair off my forearm. I had bald forearms in those days!
shampeon
#15 posted 09-18-2018 11:54 PM
I prefer to use my fingernail to test the edge. My arm hair must be perfectly coifed for me to get my “look”.
