Newbie + router table = difficulty controlling the piece
Forum topic by boobird posted 09-17-2018 07:31 PM 802 views 0 times favorited 18 replies Add to Favorites Watch
View boobird's profile
boobird
12 posts in 118 days
09-17-2018 07:31 PM
I’m attempting to create tongue/groove using the Freud 2 bit system.
Tongues are pretty easy to cut against the router table.
Grooves seem very difficult to lay flush against the fence. I’m getting a lot of resistance as I push thru. This is causing an uneven edge. Is this normal?
Should I push with a miter gauge?
18 replies so far
View chrisstef's profile
chrisstef
17761 posts in 3208 days
#1 posted 09-17-2018 07:39 PM
Smaller bites will help.
View BuffaloBrewer's profile
BuffaloBrewer
61 posts in 1020 days
#2 posted 09-17-2018 07:39 PM
If I’m picturing your set up right a following piece of scrap will help. If you are going deep you might find doing it in a couple passes will be easier too.
View Andybb's profile
Andybb
1506 posts in 805 days
#3 posted 09-17-2018 07:41 PM
Is this what you are using?
No experience with it but…
1. Is it possible you are running into the shaft because the fence is too far back?
2. I wouldn’t think that you’d use a miter gauge for a long edge but maybe for the end grain edge.
3. Are you trying to take too deep of a cut?? (probably not as most routers should be able to handle that)
Maybe someone could help if you posted a few pictures??
-- Andy - Seattle USA
View Waldo88's profile
Waldo88
207 posts in 1498 days
#4 posted 09-17-2018 07:46 PM
Take a few passes before you get to full depth on the groove (pretty much should always do this no matter what bit you are using).
View BFamous's profile
BFamous
185 posts in 322 days
#5 posted 09-17-2018 07:53 PM
Toss the router bit for the groove and use your table saw, with a dado blade if you have one…
I’ve always found the table saw is easier for cutting grooves (especially ones deeper than 1/4”) in a single pass.
You can also use the table saw to cut the tongues, but if you are having success with the router there, why change… You could actually run a two machine setup and just burn through the job once everything is calibrated properly.
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
boobird
#6 posted 09-17-2018 08:41 PM
2. I wouldn t think that you d use a miter gauge for a long edge but maybe for the end grain edge.
- Andybb
Yes I’m using that router bit. There is a bearing wheel on the shaft. The wood piece touches the bearing wheel..
View Rich's profile
Rich
3882 posts in 791 days
#7 posted 09-17-2018 09:31 PM
That should be easy in one pass. Since you mention fence, I’m assuming you’re using a fence and setting it flush with the bearing. If you aren’t, do that.
Second, I find it really hard to imagine you’re struggling to keep the board flat on the fence, even with the hardest woods. Even so, a feather board will help.
Finally, be sure the bit is sharp. I know it’s new, but Freud has surprised me a couple of times with things that slipped through inspection. Particularly since you mention the tongue bit works fine. If you were going to struggle with either, I’d expect it to be the tongue bit since it has two cutters.
View diverlloyd's profile
diverlloyd
3234 posts in 2059 days
#8 posted 09-17-2018 10:55 PM
Are you pushing the boards right to left or left to right? That’s while standing in front of the router table. It sounds like you are feeding from the wrong side. The proper side to feed from is the side that the router bit is rotating towards. That would be from the right to left on most router tables. That also forces the work piece to be pushed into the fence by the bit. The opposite way the bit forces the work piece away from the fence.
View Jeff's profile
Jeff
489 posts in 3396 days
#9 posted 09-17-2018 11:24 PM
If he was feeding backward he’d know it. The piece would pull drastically.
View CaptainKlutz's profile
CaptainKlutz
602 posts in 1696 days
#10 posted 09-18-2018 08:12 AM
hmm,
you have not shared type of wood used?
Hmm,
If tongue was easy to cut (using 2 cutters), why would groove (using 1 cutter) require more feed pressure? Groove/slot cutter is not touching the edges? Which edge is uneven?
Sorry to be dense, but the request for help does not compute?
Do you have any dust collection behind your router bit?
If slot gets jammed up with large chunks of saw dust (especially if try to feed too fast), it can interfere with cur speed and quality.
Pictures would be helpful.
View Tony_S's profile (online now)
Tony_S
955 posts in 3285 days
#11 posted 09-18-2018 08:43 AM
The cutters on the groove bit are probably on backwards/upside down.
-- It is the mark of an educated mind to be able to entertain a thought without accepting it. Aristotle
boobird
#12 posted 09-18-2018 01:10 PM
Sorry, I misspoke.
Tongues are difficult to cut. lots of resistance.
Grooves are easy and smooth
View Rich's profile
Rich
#13 posted 09-18-2018 02:31 PM
Sorry, I misspoke.
- boobird
If it’s not already set this way, adjust the cutters so they are at 90º to one another so that both of them aren’t hitting the wood at the same time. It might not eliminate what you’re experiencing, but it will be smoother.
And, like I said earlier, use a feather board or two.
View WoodenDreams's profile
WoodenDreams
290 posts in 113 days
#14 posted 09-18-2018 06:28 PM
It also makes a difference on routing feed direction for control.
View rwe2156's profile
rwe2156
3171 posts in 1682 days
#15 posted 09-18-2018 07:16 PM
That’s a 1/2” shank so the depth has to be about 1/2” correct?
That’s an very deep cut on anybody’s router table.
Doing it in 2 passes will solve the problem.
The reason its harder is obvious: two cutters vs. one.
