Honing Compound
Forum topic by BigMig posted 09-17-2018 04:47 PM 585 views 0 times favorited 13 replies Add to Favorites Watch
View BigMig's profile
BigMig
470 posts in 2810 days
09-17-2018 04:47 PM
Topic tags/keywords: honing compound green compound sharpening honing strop tip
Hey LJ team,
I’m getting better at sharpening plane irons, chisels and I want to finish with a strop and compound.
My first question is: Is green compound on a strop a good way to finish sharpening a tool?
Second question: If green compound is the right compound to finish with, is every company’s green compound the same material? Like – is the green compound from Highland Woodworking the same as Lee Valley and the same as …? Some retailers offer a small bar; others have a 1 lb block.
Thanks.
-- Mike from Lansdowne, PA
13 replies so far
View Tedstor's profile
Tedstor
1678 posts in 2830 days
#1 posted 09-17-2018 04:55 PM
Yes- that’s how I do it.
Yes- I wont say they are all the exact same at the chemical level. But I’ve never noticed a difference in results.
View TimInIndiana's profile
TimInIndiana
113 posts in 337 days
#2 posted 09-17-2018 04:57 PM
This is the stuff I use, and it seems to work just fine.
https://www.amazon.com/Woodstock-D2902-1-Pound-Buffing-Compound/dp/B0000DD35C/
View HokieKen's profile
HokieKen
7000 posts in 1335 days
#3 posted 09-17-2018 08:29 PM
Honestly, I have used many different types including Harbor Freight, Sears C-man and more expensive ones. For power stropping or buffing/polishing, there may be some noticable difference. But when it comes to stropping tool edges on a piece of charged leather, I can’t say that any one worked better than any other. As far as I’ve been able to tell, any green compound works well with stropping. If it’s hard to get charge the leather, thin it a bit with mineral oil.
-- Kenny, SW VA, Go Hokies!!!
View diverlloyd's profile
diverlloyd
3230 posts in 2054 days
#4 posted 09-17-2018 11:33 PM
Polishing compound colors are not the same for all manufacturers but rule of thumb is black,brown,white,green,red,blue. Green is the all purpose polishing compound it’s meant for stainless steel but works for almost everything.
View waho6o9's profile
waho6o9
8516 posts in 2774 days
#5 posted 09-18-2018 02:29 AM
Yes
Second ? I have no idea.
Lately I’ve been using Flex Cut gold and the green compound on a DMT plate because it’s flat, then polish on
an 8000 water stone. Works for me.
Some folks use mdf because it’s flat and others use a flat piece of maple.
BigMig
#6 posted 09-18-2018 04:37 PM
Thanks to all…now – to find a good piece of leather to make a strop.
waho6o9
#7 posted 09-18-2018 06:48 PM
View SMP's profile
SMP
121 posts in 102 days
#8 posted 09-18-2018 07:03 PM
I took an old leather belt that was too worn to wear to work anymore, cut a strip and hot glued to a stick, and bought this at my local lumberyard: https://www.amazon.com/Wood-Good-WD402-Abrasive-Powder/dp/B003NE5BFO
Only problem is my belt isn’t wide enough for my plane irons, so will probably buy the 3” strop on amazon for $10 which already comes with the green compound. Oh well.
View Planeman40's profile
Planeman40
1306 posts in 2958 days
#9 posted 09-18-2018 08:11 PM
You can buy your leather online from Tandy Leather (https://www.tandyleather.com/en/). I always keep some around the shop for various purposes. I have made a number of leather strops of various sizes and shapes for planes, chisels, and gouges. I use Turtle Wax automotive rubbing compound on my strops. Cheap and easy to obtain.
View TheFridge's profile
TheFridge
10691 posts in 1683 days
#10 posted 09-19-2018 05:05 AM
I use green. Works just fine.
View squazo's profile
squazo
111 posts in 1842 days
#11 posted 09-20-2018 01:00 AM
green is green because of the chromium oxide in it. so I would assume it is all the same because chromium oxide is chromium oxide, but who knows. I use green dialux and it is cheap and works great.
Planeman40
#12 posted 09-20-2018 01:09 AM
Reading all of this reminds me of my late father whom, as a boy, I used to watch occasionally strop his pocket knife on the leather sole of his shoe. I didn’t understand it at the time, but now I know the fine abrasive embedded in the shoe leather did the job. Great old memories! That was back in the late 1940s and 1950s.
BigMig
#13 posted 09-20-2018 04:47 PM
Replies like the ones above make the LJ site so great. Thanks team!
