I just want a simple hand plane
« back to Hand Tools forum
Forum topic by christherookie posted 09-17-2018 03:55 PM 1574 views 0 times favorited 20 replies Add to Favorites Watch
View christherookie's profile
christherookie
107 posts in 3252 days
09-17-2018 03:55 PM
Topic tags/keywords: hand plane
I’d like to have a simple hand plane for occasional use (once a month) such as when I need to shave off a millimeter off the end of a piece of wood, such as with a shooting board. I’d rather not spend more than $40 on it. Does such a hand plane exist? I can’t warrant spending any more based on my frequency of use.
20 replies so far
View Bill_Steele's profile
Bill_Steele
451 posts in 1937 days
#1 posted 09-17-2018 04:05 PM
It sounds like you are looking for a used hand plane. You’ll need decide which one you want—there are many. I would say eBay, Craigslist, or maybe a flea market might be sources you should check out. Don’t forget that at some point you may want to sharpen the plane iron—so you’ll need sharpening equipment (e.g. sharpening stones and maybe a guide).
Smitty_Cabinetshop
15705 posts in 2824 days
#2 posted 09-17-2018 04:33 PM
Used block plane for small stock would work fine. #65 or #18, and ebay has a bunch of them. Gonna have to learn to sharpen, as Bill suggests. Shoot board plane? That requires mass, so a larger (#5 or #6) plane might be in the cards as well. The #5 is common, and under $40. The #6, closer to $60-$75 in price range.
Avoid low cost NEW planes.
View WayneC's profile
WayneC
13794 posts in 4303 days
#3 posted 09-17-2018 04:44 PM
I see $20-25 Stanley #5s pretty frequently at flea markets. Look for one with a 1910 patent date or two 1902 and a 1910 patent date on it.
60 1/2 would also be another block plane to consider with the #65 (my personal favorite) and the #18 Smitty recommended above.
View OSU55's profile
OSU55
1978 posts in 2195 days
#4 posted 09-17-2018 11:44 PM
A block plane can be used on a shooting board but a 4 or 5 bench plane is a better choice. A 4 can be used in place of a block plane in many instances. Definitely used for $40. About any Stanley Bailey up through a type 19 will work fine – the old ones I have took just as much work as the newer 60’s and 70’s and they all work about the same properly tuned up. I do prefer the larger OD adjuster wheel, just easier to turn. The one piece skew levers work ok, but you want a cast adjuster yoke, not the 2 pc stamped.
Good luck staying at just one. Once someone figures out how to tune and use a plane they dont stop at just 1. When you realize how nice they are to use sandpaper and powered sanders become almost obsolete.
View BlasterStumps's profile
BlasterStumps
993 posts in 645 days
#5 posted 09-18-2018 01:35 AM
Have you seen these sanding shooters. You can buy one or make one. No sharpening, just change the strip of sanding medium. I made the one I use and it works well enough to tidy things up when needed.
Mike
https://www.youtube.com/watch?v=MbAZkXm0WmA
-- "I build for function first, looks second. Most times I never get around to looks." - Mike, western Colorado
View bandit571's profile
bandit571
21801 posts in 2889 days
#6 posted 09-18-2018 01:51 AM
Timetestedtools just MIGHT have a plane that will suit….
Do NOT get the one that Lowes sells ( Kobalt Smooth plane) unless you need a doorstop.
View LittleShaver's profile
LittleShaver
424 posts in 825 days
#7 posted 09-18-2018 12:26 PM
I picked up a Stanley-Bailey Type 14 number 4 at an estate sale weekend before last for $5. An hour of cleaning and sharpening and it was making great shavings.
-- Sawdust Maker
View Willscary's profile
Willscary
25 posts in 126 days
#8 posted 09-18-2018 12:30 PM
What about Taytools? They seem to get good reviews. Are they ok as a starter plane?
View waho6o9's profile
waho6o9
8525 posts in 2782 days
#9 posted 09-18-2018 12:52 PM
WayneC
#10 posted 09-18-2018 12:55 PM
- Willscary
The three reviews on amazon indicated that the Taytools planes need to be tuned including some filing. For the price an old Stanley would be similar to set up and less expensive. As I said above, look for one with a single 1910 patent date or a 1910 patent date and two 1902 patent date. There are lots of other good ones out there from Stanley and other Manufactures such as Union, Millers Falls, Sargent, and Ohio as well as ones that have been rebranded e.g. older craftsman, keen kutter, Winchester, etc. The 1910 advise is to help someone who is new to bench planes to get their hands on a quality plane. Once you have a quality plane, have tuned and used it, it’s easier to select planes of other manufacture and vintage.
WayneC
#11 posted 09-18-2018 12:57 PM
- bandit571
And Don is an honest guy. Known him online 8-10 years.
View diverlloyd's profile
diverlloyd
3235 posts in 2063 days
#12 posted 09-18-2018 01:22 PM
Check the local flea markets and antique stores. If your location is what it says Drive down to exit 76 and go to the exit76antique mall. They have lots of hand planes. Start on the left side and the 1st isle on the wall 4 booths down on the left side had a couple nice planes for a decent price. There is also a plane dealer in there that has rare planes but they are not cheap. Fun to look at. Also check auctionzip.com for your local auctions. Don’t buy a plane with a stamped frog you want a good solid cast one.
View WoodenDreams's profile
WoodenDreams
304 posts in 116 days
#13 posted 09-18-2018 06:36 PM
A occasional hand plane user can easily start out with a inexpensive plane from a hardware or box store. My 1st plane was a small hand plane under $10. Later on I added some addition planes as the need dictated. Then later I picked up some sharping stones.
View Maddux Woodworks's profile
Maddux Woodworks
2 posts in 194 days
#14 posted 09-19-2018 04:40 AM
This is the plane I got not long ago, and it has done very well, and doesn’t break the bank.
Stanley 12-905 14-Inch No.5 Contractor Grade Smooth Bottom Bench Plane
https://www.amazon.com/Stanley-12-905-14-Inch-Contractor-Smooth/dp/B00004UDKW/ref=sr_1_1?ie=UTF8&qid=1537331823&sr=8-1&keywords=Stanley+12-905+14-Inch+No.5+Contractor+Grade+Smooth+Bottom+Bench+Plane
I’ll be posting a review on it soon.
- Maddux Woodworks
https://www.youtube.com/channel/UCjy1O4CUcpD9iXWkXzGJswg
-- Brandon
View TheFridge's profile
TheFridge
10767 posts in 1692 days
#15 posted 09-19-2018 05:02 AM
I have a #4 I could let go for 40 minimum. Shipping included. Tuned and shiny (probably doesn’t help you). You could take it out the box and use it. PM if interested.
The stuff you see in a box store is crap.
