Dust collection with wet/dry vac
Forum topic by Praki posted 1874 days ago 6219 views 0 times favorited 16 replies Add to Favorites Watch
View Praki's profile
Praki
192 posts in 2167 days
1874 days ago
Topic tags/keywords: question
Hi LJs,
I don’t have any kind of dust collection system in my garage. The higher powers have issued a directive to “do something about the dust in the garage or else…”. I am thinking of cobbling something together with a wet/dry shop vacuum and looking at a Ridgid or Craftsman 16 gallon shop vac.
Right now I only have a table saw, router and I plan to get a planer soon. I mainly work with solid wood and MDF. I don’t mind the inconvenience of switching the vac from machine to machine that much.
My question is, would this work okay or will I be dissatisfied with it and forced to acquire a real dust collection system? If somebody would share their experience, that would be much appreciated!
Thanks
-- Praki, Aspiring Woodworker
16 replies so far
View unknownwoodworker's profile
unknownwoodworker
219 posts in 1874 days
#1 posted 1874 days ago
It’s been my experence the shop vac will not handle the planner. And if dust is your issue use a dust collector with a 1 micron filter. Dust collectors are portable.
-- ??? My mistakes heat the house. It's very warm in here. ???
View Toolz's profile
Toolz
889 posts in 1913 days
#2 posted 1874 days ago
Also if you do go the shop vac route consider small cyclone type system between your shop vac and your tools. It is amazing how often you NOT have to clean out the vac filter with one of these installed.
-- Larry "Work like a Captain but Play like a Pirate!"
27262 posts in 1992 days
#3 posted 1874 days ago
Hi Praki,
I use a shop vac for my router table without any problem. The difficulty with the planer is that it will have a 4” dust port on it. Stepping it down may produce a problem with moving the chips through the hose. I use a portable 3/4 hp collector for my planer (Delta 22-580). But the biggest issue with using a shop vac or, as in my case, a small portable system is the lack of control of the fine dust- <30 microns. A good dust control system should be controlling particles in the 1 micron range for health concerns. Breathing in these small particles can cause long term health issues.
View GaryK's profile
GaryK
10263 posts in 2159 days
#4 posted 1874 days ago
I like Toolz’s idea.
Praki
#5 posted 1874 days ago
Toolz and Gary, are you referring to the Mini CV06 at ?
http://www.clearvuecyclones.com/Order_Page.htm
Scott, Lately, I have become aware of how much the dust bothers me and I do want to take this issue seriously. From what I have read so far, it was not very clear to me if the wet/dry vac system works or not.
Thank you all for your sharing your experience.
View TroutGuy's profile
TroutGuy
222 posts in 1882 days
#6 posted 1874 days ago
I’m using a Rigid 12 gal. shop vac (model WD12450) in my shop “for now”. It does fairly well on my small table saw, and when used with my Delta 22-580 and a 4×2 1/2 adapter, it works quite well, provided it’s clean when I start. I take the filter out and blow it clean with compressed air (DO THIS OUTDOORS!). Be sure to blow from the inside, out (opposite of normal flow); as well as cleaning the pleats.
If I start with a good clean filter/vac, I could clean the floor with a foxtail and dustpan. To be fair though, I’m generally running small quantities at a time (< 10 bd-ft). YAMMV
I also bought the 3-layer, 1 micron filter cartridge. That cartridge really DOES decrease the amount of fine dust in the air and on surfaces. The downside is that it clogs VERY quickly. I ended up going back to the ‘standard’ filter (5 micron, I think?), buying a decent respirator (every woodworker should own and USE one IMHO), and using the fine filter only when I’m generating a LOT of fine dust (sanding).
I’m also looking into buying or building a separate air filtration unit for the shop.
-- There is nothing in the world more dangerous, than a woodworker who knows how to read a micrometer...
View flink's profile
flink
94 posts in 1891 days
#7 posted 1874 days ago
I use my 16 gallon Shop Vac more often than my 1029Z. I run the extra-fine dust bags (the ones for drywall dust) and a clear stream hepa filter. There’s no dust in the air except what never made it to the vacuum.
The clear stream filters rock. I use my shop vac with my power planer (hand model) and for all sanding operations.
If you’re going to be generating serious chips, that clearvue mini cyclone looks to be the best answer. I’m planning on getting one soon (I hope. I spend way too much buying wood ;-) ).
-- Made lots of sawdust and pounded some nails. Haven't finished anything, though.
View ND2ELK's profile
ND2ELK
13495 posts in 1944 days
#8 posted 1874 days ago
I would buy a : Delta 50-760, 1 1/2 HP, 1-Micron filter bag, portable. Cost between $300-$350 with shipping. Fine Woodworking rated this machine #1 in its class.
Seeing that the Higher Powers wants the dust to go away, maybe you can talk them into paying half.
God Bless
tom
-- Mc Bridge Cabinets, Iowa
teenagewoodworker
2727 posts in 1939 days
#9 posted 1874 days ago
i agree with ND2ELK, I’m looking into a dust collector as i start to get some stationary power tools and due to the great reviews and that it has a 1 micron bag i would go with the Delta 50-760
teenagewoodworker
#10 posted 1874 days ago
look into this one too. it got great reviews, has a 1 micron bag, and is supposed to be quieter than the others
http://www.amazon.com/JDS-14040-Dust-Force-Horsepower-Collector/dp/B0007Y75IE/ref=pd_bbs_4?ie=UTF8&s=hi&qid=1207417365&sr=8-4
hope this helps
GaryK
#11 posted 1874 days ago
praki, no not that one. This kind sits on a metal trashcan. It’s cheap and it works.
http://www.rockler.com/product.cfm?page=1515&filter=dust
Praki
#12 posted 1873 days ago
GaryK, Thanks for the clarification.
teenagewoodworker – thanks for the pointer. It is on my list of candidates now.
ND2ELK – thanks, I should have no trouble getting the budget approved for this cause :)
flink – can you point me to a “clear stream filter”. I am not entirely sure what you mean.
TroutGuy – thanks for sharing your experience. I do use a respirator and it helps.
View Joey's profile
Joey
275 posts in 1986 days
#13 posted 1873 days ago
i Use a rigid 16 gallon in my shop. i use it on everything from the tablesaw, bandsaw, rigid oscilating sander, jointer, and planer. It will work with the jointer and planer but because it’s shavings and not dust, the vac will fill up alot faster.
You’ll need to buy some 4” hose and adapters to go from 4” to 2 1/2”.
Also take some old stockings or pantyhose and put over the filter, this will help keep the really fine dust from MDF or sanding from clogging the filter too fast.
Keep the filter clean and empty the container as often as possible, and you should be ok.
-- Joey, Magee, Ms http://woodnwaresms.com
View motthunter's profile
motthunter
2129 posts in 1969 days
#14 posted 1873 days ago
i have used my shop vac for years and still plan to get my dust collector up and running htis year to do a better job.
-- making sawdust....
View ChicoWoodnut's profile
ChicoWoodnut
904 posts in 1986 days
#15 posted 1873 days ago
Hey Praki, Click on this link and choose the “Shop Vac Cyclone” video. Onieda sells a similar one which you can find here. These basically keep the chips out of your shop vac like the one Gary linked to. I don’t know if one is better than the other.
