Spray brushing lacquer?
Forum topic by Tim Kindrick posted 08-04-2011 09:27 PM 22772 views 0 times favorited 12 replies Add to Favorites Watch
View Tim Kindrick's profile
Tim Kindrick
369 posts in 2576 days
08-04-2011 09:27 PM
Topic tags/keywords: question spray gun finishing refurbishing
I’m pretty new to spraying on finishes so I need help with this question. I have a few cans of Deft Clear Wood Finish, which is a “Brushing Lacquer”. On the back of the can it clearly states under Applications: “For brushing only. This product must not be thinned or sprayed”. I know that lots of other products say “Do Not Thin” but are commonly thinned all of the time without a problem.
I have a new HF HVLP sprayer that I’ve never used and I would like to spray my next project with lacquer without having to go out and purchase new products. Is there a specific reason why I can’t spray this type of lacquer?
-- I have metal in my neck but wood in my blood!!
12 replies so far
View rda327's profile
rda327
26 posts in 2665 days
#1 posted 08-04-2011 09:51 PM
I thin and spray brushing lacquer all the time. I called one manufacture of brushing lacquer and was told that he could not tell me not to thin or spray brushing lacquer BUT his customers do it all the time. I have been spraying it for about 2 years with no problem.
-- Roger, Jasper Tn.
Tim Kindrick
#2 posted 08-04-2011 11:03 PM
Thanks guys!! Like I said, I’m pretty new to spraying finishes and this lacquer was left over from last year when I was brushing this lacquer on projects.
Any tips on the amount of thinner I should use?
View DrDirt's profile
DrDirt
4424 posts in 3764 days
#3 posted 08-04-2011 11:21 PM
Yep it sprays awesome…and is 37 bucks a gallon at lowes.
I thinned it about 1/3
I have a spaghetti sauce jar and I go roughly 2/3 lacuer 1/3 thinner, shake it up and ready to go!
View rusty2010's profile
rusty2010
150 posts in 2580 days
#4 posted 08-04-2011 11:48 PM
I sprayed Deft 25 years. The brushing laquer is the same as it was when advertised spray laquer. I called Deft about 4 years ago when they changed the can. The said the did this to meet California EPA. I have a Titan hvlp system. I now have to thin mine about 10%. I would not suggest any more. The laquer thinner can do some damage especially if your new to spraying. Start with a thin coat, sand and vacuum the dust. your next coats should be heavier, now leave the white powder there the next coat will melt it and help build up. I also use Conversion varnish by Target Coatings. Their waterborne and safer There is a learning curve, but it’s worth the effort. Also, it is more expensive and a lot safer without the oder. good luck
-- check, recheck then check again
DrDirt
#5 posted 08-05-2011 12:09 AM
I have the HF gun, and sometimes have to do more fiddling to get good atomization – - I find the extra thinner helps level out any texture issues. I would suggest some level of thinning and stick with that while you learn how to run your gun – then start tweaking your viscocity to get the build you want
View Earlextech's profile
Earlextech
1162 posts in 2712 days
#6 posted 08-05-2011 12:19 AM
Sprays great! Do it!
View Arlin Eastman's profile
Arlin Eastman
4230 posts in 2583 days
#7 posted 08-05-2011 12:22 AM
I was a little confused at first when I read Spray Brushing. I did not think a person could do both at the same time. lol
Arlin
-- It is always the right time, to do the right thing.
View Steven H's profile
Steven H
1117 posts in 3082 days
#8 posted 08-05-2011 12:47 AM
Its the same thing but just solvents added to prevent it form drying off fast when brushing.
View cutmantom's profile
cutmantom
405 posts in 3057 days
#9 posted 08-05-2011 02:01 AM
dont forget to use a respirator and good ventilation
DrDirt
#10 posted 08-07-2011 07:43 AM
You got that right cut man cough cough…..That is the downside of lacquer
View fladdy's profile
fladdy
93 posts in 3035 days
#11 posted 08-30-2011 02:18 AM
Just used Deft lacquer, thinned about 1/3. My first time spraying and it turned out magnificent! I will be posting pictures soon, hopefully.
-- Fladdy
Tim Kindrick
#12 posted 09-03-2011 02:34 AM
Thanks Fladdy…... I can’t wait to try it on my next project!!!!!
