Delta Mortiser Running in Slow Motion
Forum topic by bruc101 posted 09-16-2018 06:30 PM 389 views 0 times favorited 10 replies Add to Favorites Watch
View bruc101's profile
bruc101
1249 posts in 3691 days
09-16-2018 06:30 PM
I’ve got a Delta Mortiser that I bought several years ago. I’ve not used it in several months due to having a more powerful one.
Yesterday I started to use it, and when I switched it on, it ran in slow motion and kept getting slower. The motor also warmed up more than usual so I switched it off.
Anyone have any suggestions as to why and a fix for it?
I’ve got it set up to run only 3/8” mortises.
Thanks in advance.
-- Bruce Free Plans http://plans.sawmillvalley.org
10 replies so far
View lumbering_on's profile
lumbering_on
385 posts in 639 days
#1 posted 09-16-2018 06:38 PM
Have you checked the tension on the belts? Or is this a direct drive?
117242 posts in 3726 days
#2 posted 09-16-2018 06:51 PM
Many times problems like this pops up it involves sawdust clogging things up.
runswithscissors
2846 posts in 2174 days
#3 posted 09-16-2018 10:48 PM
Could be a start capacitor, maybe?
View GR8HUNTER's profile
GR8HUNTER
4739 posts in 861 days
#4 posted 09-17-2018 02:26 AM
not a start cap from what he describes :<((
maybe motor cant breathe if it got hot :<))
bruc101
#5 posted 09-17-2018 05:20 AM
Thanks guys for your replies. I’m going to open up the motor today and see what I can find. I’ll let you know.
bruc101
#6 posted 09-17-2018 07:12 PM
I was able to get the fan off the top and blow some air down into the motor. It acted like it wanted to pick up and go and then there will be a little bump and it starts slowing down again. The motor also starts getting hot the longer I let it run.
View DBDesigns's profile
DBDesigns
139 posts in 146 days
#7 posted 09-19-2018 07:20 PM
This is a blind guess but it sounds like a bearing or some kind of drag on the motor shaft.
-- I remember when Grateful wasn't Dead
View waho6o9's profile
waho6o9
8438 posts in 2726 days
#8 posted 09-19-2018 07:36 PM
That’s odd.
http://www.deltamachinery.com/support/customer-support
Technical Support
Product Assembly, User or Other Product-Related Questions
1-866-999-1499
Good luck
View pintodeluxe's profile
pintodeluxe
5758 posts in 2962 days
#9 posted 09-19-2018 08:31 PM
Clogged or bent mortising bit? Remove bit to rule that out.
Bad Run Capacitor? If yes, replace both capacitors.
View bigblockyeti's profile
bigblockyeti
5230 posts in 1870 days
#10 posted 09-19-2018 11:39 PM
I believe those have a single capacitor, check it and replace if bad. I can’t remember if they have a centrifugal switch for the start windings but having that fail would result in slow running and getting hot quickly.
