I've recently build a Gramercy Tools Turning Saw from their kit. I think it turned out pretty well.
I've read their design thoughts and they discuss a lot of the design issues, but there doesn't seem to be any discussion of the length of the cheeks (or arms) of the saw. If you're going to hold it by the cheek, clearly the cheek needs to be big enough to hold on to. But if you're going to use the handle as the Gramercy design does (which makes sense for a turning saw), the cheek doesn't need to be that big. Is there any reason NOT to make a bow saw with shorter cheeks?
I think I'm going to head out to the shop to do a little experimenting….
Probably can shorten it but likely need to make some other changes. I would believe it would start to behave different in regards to blade tension as you started to change the length of the arms and fulcrum point. Might have to twist it a few more times or less times to get to same tension. Might need to change thickness or width of the arms to compensate. As you start to do this sort of stuff the saw may become less balanced in use.
As they mention you will also have a decrease in cut depth but may not be an issue depending on how you are using the saw. Easy enough to whip out a few different arms to test and might find out a set up that you find more comfortable using.
I built mine several years ago and liked it but really haven't used it too much after the initial honeymoon period.
I am not a user of a bow saw, but I agree with TravisH regarding depth of reach and the tension issue.Balance is also an issue, the feel in the hand, especially if using the handle because the weight will work against you & might cause difficulty following a line.
What ever you determine via your shop experimentations, post the results, I'm curious to see what you find out.
I'm keeping the arms symmetric (same length above and below the stretcher), so tensioning should be the same. I expect I could lighten up the wood more due to the shorter level-arms, but I left it pretty close to the one with the 12" cheeks (5" from stretcher to blade or tensioning line, compared to 2.5" on this one with 7" cheeks).
Yeah, a decrease in cut depth will happen, but it's a turning saw. Don't think I'll find myself in the middle of a large board all too often…
Got the epoxy curing on the handles now. I'll hopefully get a chance to test-drive it tomorrow evening.
Should be easy enough to do 2 arms with a set of holes for the blade holders and matching notches for the cord on the tensioning side.
It might not look terribly pretty, but should give you a chance to check several different positions (Both symmetric and offset) from just the one build.
Thanks, Kevin. I also got a note from Joel at Tools For Working Wood saying that he's seen bow saws with all different lengths of cheeks. Shorter ones can mean more tension, and longer ones less tension, but I think I'm far enough away from breaking the wood that it's up to how many cranks I give the toggle.
There won't be any shop time the next few evenings, so it'll probably be the weekend before I get to play, but I'll definitely report back when I do get time.
After a morning of fixing errors and tweaking the fit, I got the shorty bow-saw together. It cuts fine, but as you would expect, the depth of cut can be an issue. But it's noticeably lighter, and less "floppy" (by which I mean, wanting to take a small wobble on my part and turn it into a big swing of the saw - rotational inertia matters, it turns out), and I suspect I'll reach for this one first, and go to the more traditionally proportioned saw when I need more depth of cut. Note that this is a 12" long blade.
Time to take it apart and clean things up a bit before getting a coat of oil on it.
This looks like a 18th century coping saw, neat.
Question: do you hold the handle or the arm when using? I can see advantages to both grips, curious what an expert thinks.
Enjoy the new tool Dave, well made.
Well, I've only used it to make two cuts, but I should use the handle for better control, I think. But starting a cut, it's awfully tempting to grab the arm.
My understanding is that by holding the handle, and extending your index finger along the side of it, you're more in control of all the angles involved, and can rotate the handle to turn your cut. Basically the same grip as a gents saw.
That said, I made the handles from a scrap of ziricote I had laying around, and if they don't work out, I'll make new ones. I plan to order some spare pins from Gramercy Tools so I can experiment with handles, too.
Dave, I'm still working on the "floppy" thing. The smaller the saw the less of an issue it becomes. Just posted the big one on the saws thread, no one handing on that one!
Saw that, Kevin. I was remembering when I was a kid and we had a metal framed bow saw for trimming branches. I was a scrawny kid, and there were times it felt like the saw was going to spin me around. I wonder if that's coloring my perception. Either way, I think I'll like having a smaller bow-saw in the shop.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
