Vertical drawer dovetails...how?
Forum topic by groland posted 09-16-2018 03:58 PM 437 views 0 times favorited 8 replies Add to Favorites Watch
View groland's profile
groland
211 posts in 3615 days
09-16-2018 03:58 PM
Topic tags/keywords: vertical drawer dovetailshow
I need to build some drawers for a drill press cabinet I am making. The drawers will be run on metal tracks, so their sides will need to be 1/2 inch in from the cabinet sides. I want to make the drawer fronts of 3/4 inch birch plywood and the sides of 1/2 inch birch ply. I have seen cases where dovetails are used to anchor the drawer sides to the fronts. These dovetails are made as tracks, vertically on the inside of the drawer front, and along the vertical edge of the sides. I have a router table that works well, so I think I could make such drawers, but I can find no information on best practices for doing this.
I assume the router bit will need to be, maybe, 3/8 inches wide and 1/2 inch deep? The “1/2 inch” ply is, of course, less than 1/2 inch.
If anyone knows a good article or video on how to do this, I would greatly appreciate any links you could provide.
8 replies so far
View ocean's profile
ocean
123 posts in 1036 days
#1 posted 09-16-2018 04:02 PM
Half blind dovetails. Look in Youtube for how to videos. The 1/2” ply will be a problem – chip outs
-- Bob, FL Keys
View TheFridge's profile
TheFridge
10747 posts in 1689 days
#2 posted 09-16-2018 05:07 PM
Typically done with a dovetail jig.
View Rich's profile
Rich
3883 posts in 792 days
#3 posted 09-16-2018 06:03 PM
- TheFridge
^^^^+1.
What you’re describing is called a rabbeted half-blind dovetail. The process is to cut a rabbet on the side of each drawer front that’s 1/2” wide and slightly deeper than the depth of your dovetail. After that, the process is the same as any other half-blind dovetail but made slightly more challenging because you can’t get the saw to much of an angle.
Using a jig like the Leigh, it’s a piece of cake. I’ve done them several times.
Here’s my suggestion. It’s just a piece of shop furniture, not a museum piece. Do a false front. In other words, build your drawer box out of the 1/2” plywood to the correct dimensions to allow for your slides, then screw your 3/4” birch plywood, cut full width, to it.
View cracknpop's profile
cracknpop
334 posts in 2552 days
#4 posted 09-16-2018 06:10 PM
Are you perhaps asking about a sliding dovetail joint like this…
If so, here is an article how to make them.
https://www.finewoodworking.com/2009/01/25/how-to-cut-sliding-dovetail-joints
-- Rick - I know I am not perfect, but I will keep pressing on toward the goal of becoming all I am called to be.
TheFridge
#5 posted 09-16-2018 06:53 PM
Ohhhh. I see said the blind man.
groland
#6 posted 09-16-2018 07:08 PM
crackenpop,
Yes, yes, thank you, THANK you!
Sorry guys, but I’m so dumb, I just couldn’t think of the adjective, “sliding”, for sliding dovetails.
For anyone else who happens upon this thread, this video:
https://www.youtube.com/watch?v=78Gd73MvgOc seems like a good introduction.
Problem solved…just need to get a suitable router bit now!
View shawnn's profile
shawnn
124 posts in 1568 days
#7 posted 09-19-2018 04:16 PM
I think they’re also called French dovetails. I’ve done them, not overly difficult on my Incra router table. Probably the trickiest part is setting up stops to cut the drawer fronts. The drawer sides are cut the entire width top to bottom.
Smitty_Cabinetshop
15701 posts in 2821 days
#8 posted 09-19-2018 04:35 PM
You could also get one of these.
