Little help? PM 54A jointer infeed table frozen
Forum topic by Bertha posted 660 days ago 2169 views 1 time favorited 102 replies Add to Favorites Watch
View Bertha's profile
Bertha
13115 posts in 865 days
660 days ago
Hi guys, I just purchased a 6” Powermatic 54A jointer and she’s a beauty. She’s been sitting down for some time and the infeed table is absolutely frozen at 1/4” cut depth. I loosened all the gibs and knobs, slathered in in WD40, and even come-along’d it with a rubber mallet. It’s going nowhere. Any suggestions?
102 replies so far
View MedicKen's profile
MedicKen
1561 posts in 1634 days
#1 posted 660 days ago
Try a little better penetrating oil. Kroil, PB Blaster or even some ATF and kerosene.
Bertha
#2 posted 660 days ago
Thanks Ken, you know anything about this jointer? It appears that the infeed table is adjusted by a lever crank that can be stopped along its arc’d path by a locking knob; once locked, it looks like you can fine adjust for height using the threads on the crank. I’ve tried everything and it won’t budge. I’ve never used this jointer before; I probably should have investigated before I purchased it. The manual’s no help. It just says “raise the infeed table”.
I’ll pick up some PB tomorrow.
View Lee Barker's profile
Lee Barker
1889 posts in 1022 days
#3 posted 660 days ago
Al, the color coordination is exquisite.
Second the Kroil or the brew. They’re top o’ the heap for breaking things loose.
View Don W's profile
Don W
9972 posts in 739 days
#4 posted 660 days ago
I agree with Ken. Just keep pumping the stuff to it. It’ll come eventually.
MedicKen
#5 posted 660 days ago
I am not familiar with this jointer. I tend to use Kroil as a good penetrating oil instead of WD40. I have found that the Kroil works really well on the old, rusty machines I seem to drawn to. I have also used the ATF mixture as well. In fact, the ATF mixture is probably the optimum for penetration. You might take a look at the Powermatic site and see if there is a manual available, if you dont have one. I would shy away from the blue wrench, torch, the paint is really nice but wont be after the blue wrench
Bertha
#6 posted 660 days ago
Thanks guys, I’ll look for some Kroil. I’m guessing automotive store? I appreciate y’all taking the time. Al.
Beginningwoodworker
13225 posts in 1844 days
#7 posted 660 days ago
Congrats thats a nice jointer.
-- CJIII Future cabinetmaker
View cabmaker's profile
cabmaker
1030 posts in 980 days
#8 posted 660 days ago
I had a delta approx. early 60 s vintage that had some really tiny allen head set screws to tighten down once the beds were where you wanted them. Seems like they were machined on the plane of the dovetail way and just above the sliding joint. I never knew they were there until I needed to adjust once. Anyhow that was delta and ten years or so back. BTW that 54a is a fine looking machine. I was going to buy one on sale 6-7 yrs ago at fort worth woodcraft. I arrived at the store ten minutes before the posted closing time. The fellow inside beat me to the door and locked it yelling they were closed. Oh well, I still had the cash in my pocket and have not been back since. Back to the orig. subject: best I remember mine had two set screws on each side and did not stand out much cause they were painted gray like the machine. Good luck
View Letorix's profile
Letorix
119 posts in 675 days
#9 posted 659 days ago
PB Blaster is what I used on my marine stuff! Amazing stuff, gratz on the jointer.
No disrespect for WD40, but they aren’t in the same league
View coloradoclimber's profile
coloradoclimber
547 posts in 2239 days
#10 posted 659 days ago
Al, I have that exact jointer and I like it a lot. You can download the manual here or the direct link. I’m sure you already checked this but there is a locking screw and travel limiter on the back side of the infeed table. Obvious I know but I missed it the first time I tried to adjust the infeed and it wouldn’t move.
View Grandpa's profile
Grandpa
2381 posts in 847 days
#11 posted 659 days ago
Well, I tried to go back to a paper about testing penetrating oils. It didn’t work!! I think the ratio was 50/50. Acetone/power steering fluid. It was the best of all the things tested. I can’t remember if Kroil was listed but I know it beat WD-40 in a big way. Kroil is great….also PB Blaster. I think there is something locked down and this machine has never been used….since new.
View philip marcou's profile
philip marcou
263 posts in 768 days
#12 posted 659 days ago
Al,
This is why I always CLEAN any old or second hand new machine acquisition- I bet you have missed some little grub screw or similar item which is locking the bed….But if you are sure there is nothing hiding then the , er, judicious application of heat along the sliding ways will get it. Gas torch is best but even one of those heat guns may do.
Bertha
#13 posted 659 days ago
Thank you so much, gentleman. I have already removed the lock-screw (a little wimpier than I expected on a machine like this) and loosened the gib screws. The gibs look pretty well locked in there and I wasn’t getting any movement of the bed last night. Immediately behind the depth lever there’s a casting connected to the articulated arm that is tapped. I put a large bolt in the tap and beat on it with a deadblow. Still nothing. I’ve got a torch but I’m scared to use it on that pretty paint (yes, David, scroat color; not yellow). It looks like there’s only so much the adjusting mechanism will take, so I’m not going to beat on it much more. I’ll try some chemical remedies before resorting to the torch.
Just in case, what color is Powermatic yellow!? In case I’m painting;)
View chrisstef's profile
chrisstef
5301 posts in 1178 days
#14 posted 659 days ago
Well Al, it looks like the machines no good, from all the research ive done the only thing that will cure a frozen Powermatic jointer is to send it to New England where the locals can swear and demean it until it gives up. Ive got just the right place for it buddy located dead in between NYC and Boston.
-- "there aren’t many hand tools as awe-inspiring as the #8 jointer. I mean, it just reeks of cast iron heft and hubris" - Smitty
Bertha
#15 posted 659 days ago
Well, the facts are the facts, Christef. PM me your address and I’ll get this hunk of junk over to you. Does the post office have one of those “if it fits, it ships” boxes that’ll fit? ;)
showing 1 through 15 of 102 replies
