Upgrading the fence on my 1946 Unisaw, looking for feedback
Forum topic by MikeUT posted 09-14-2018 07:02 PM 707 views 0 times favorited 7 replies Add to Favorites Watch
View MikeUT's profile
MikeUT
179 posts in 1536 days
09-14-2018 07:02 PM
I am looking in to options to replace the fence system on my 1946 Delta Unisaw. I want something more precise and repeatable, my budget is $350-ish. I’m considering:
- A shop fox or Vega Beismeyer clone ($250-300 range)
- Delta T2/T3 fence system (around $220 on home depot)
- Build my own rails and use Very Super Cool Tools fence (probably around $350 all-in)
- Build my own rails and buy a heavier duty Biesmeyer fence. (Probably around $250 all-in)
I am leaning towards building my own rails and getting a VSC fence with aluminum extrusion or a Biesmeyer. Is it worth an extra $100 to have the extruded aluminum fence? Are there better options out there?
Any/all opinions are welcome and appreciated. Thanks!
7 replies so far
View Bill White's profile
Bill White
5107 posts in 4137 days
#1 posted 09-14-2018 07:27 PM
I have the Shop Fox Classic on my Grizz. It has been (and is) A really good fence. Set and forget.
-- bill@magraphics.us
View toolie's profile
toolie
2147 posts in 2805 days
#2 posted 09-15-2018 01:59 PM
One vote here for T3. I have a delta T2 on a change 113 and it is as repeatable and reliable as the OEM fence on my ridgidl 2412.
View GR8HUNTER's profile
GR8HUNTER
4933 posts in 889 days
#3 posted 09-15-2018 03:21 PM
either one will be better :<))))
View TheFridge's profile
TheFridge
10509 posts in 1663 days
#4 posted 09-16-2018 03:20 AM
Out of 3-4 viable fence options I’ve used, I like a bies even over a unifence.
runswithscissors
2874 posts in 2202 days
#5 posted 09-16-2018 11:05 PM
Much as I like the Unisaw, the original fence to me is the weak point. On a Rockwell contractor’s saw I had many years ago (same fence as the Uni), I despised the fence, and made my own rails and T-square type fence. Worked fine. I have heard many good things about the Unifence, but have never used one. Otherwise, I think any decent T-square fence would serve you well.
I made my own rack and pinion fence (real one, like on the DeWalt job site saw), just because I like the idea, but I wouldn’t do it again. It actually works very well, but was too fussy to make. The hardest part was finding steel square tubing that would fit to telescope nicely, but not be too sloppy. The outer tube has to be the exact right wall thickness.
It has the advantage that it gives generous cutting width not only to the right side of the blade, but left side also, while staying within the table footprint when retracted. This required that the actual fence could have 3 mounting positions—left, right, and center. I still use it, but it’s getting to the point where it needs a tune up.
View jonah's profile
jonah
1877 posts in 3475 days
#6 posted 09-17-2018 03:38 PM
I absolutely love my VSCT fence. Building the rails isn’t trivial, but it’s very easy as metalwork goes. Alan’s videos take you through the whole process step by step.
If you can find a local metal shop that has drops the size you need, you could get the steel for almost nothing.
The VSCT fence is definitely a few steps above the T2/T3/Vega fences. I’ve not used the Shop Fox they sell now, only an older model. It’s not bad.
View shawnn's profile
shawnn
120 posts in 1542 days
#7 posted 09-19-2018 04:00 PM
I have an older PM-66 with an Incra fence and love it. I don’t know that you can get a more repeatable setup. Offers a lot of options as far as total rip width too, as the rails can be set further back; I currently have about 26” rip. I got mine used (and somewhat abused) for about $250, it’s the older style Ultra positioner but works perfect for me.
