| Forum topic by amagineer | posted 655 days ago | 489 views | 0 times favorited | 3 replies | ![]() |
655 days ago |
I need some help from the LJ’s. I have a Dewalt dw733 planer. I put a piece of twisted hardwood in and damaged the right inside area of the planer blades. I purchased the replacement parts and now am having trouble with how the torsion spring should be mounted. The spring keeps the blade shaft locking plate in position. As you can see in the picture, the spring is held by a screw and washer to the frame. The spring in the picture is not under tension. If someone could take the cover off of their planer and tell me how I should position the spring under tension, I would be grateful. Thanks Don
-- Flaws are only in the eye of the artisan! |
