so just took delivery of my new router table and lift and I read in the manual that "above the table bit changes are not possible with a Bosch 1617?" due to the short motor length on this router lift??
As I have an original PRL and use the offset wrenches I initially thought that wasn't true but I just called WP as I had considered upgrading my original PRL to the version 2. No above the table bit changes with the newer lift. That would be a deal breaker for me. They said the same for the Porter Cable too. Surprised they would do that for two very popular router models.
Me too, Andy. So with the new version you can't even do above table changes with offset wrenches? I don't get it. Are you supposed to lift the plate out of the table or something?
Even though I talked to them today I am still skeptical. Even with the router all the way down I can still reach the collet nuts with the offset wrenches. If the bit is high enough to use on the table I just can't see how it can't be reached and changed with the offset wrenches. Hmmm.
Yes, I would think somebody would have mentioned this before. Hopefully somebody with a V2 and a Bosch or PC will comment.
So I just spoke to Woodpecker's Customer Service. They claim offset wrenches make it possible, and/or a collet extender (Which I'm not loving).
Let's hope someone chimes in with a Bosch 1617 in use… at this point I'm happy with the product, and would buy a different router motor if needed honestly. BUT still worth knowing.
I have a PC router in my router table, and I can raise and lower the router bit from above the table. I can also use the offset wrenches to change router bits. I have a plate that allows me to remove a good bit of the plate to get to the bit. I think it's a Rousseau (spelling). I can't get the bit above the plate/table, but that isn't a problem.
I have two 1617's that I use for other jobs. I got the PC specifically because it was highly recommended for router table use.
- Kirk650
Thanks, Kirk.
So is your LIFT a Woodpeckers PRL V2? This is "problem" I'm suspecting is unique to that specific lift/plate.
With the PC routers, and the Bosch 1617's, you don't actually need a lift. The routers can be raised and lowered from above the table. In my first homemade router table I had the router attacked to a rectangular plate that was in place of the router base. I just lifted out the router and plate and changed bits. The fancier router table I have now has the PC router attached to a similar rectangular flat plate (maybe I can get the name of it) that has round inserts that snap into place. I use the 'crank', supplied by PC, to raise the bit as high as it will go, snap out the round inserts and use the offset wrenches to loosen the Collet and remove the bit. Easier to do than it is to write this. Let me see if I can find the model of the router table plate I use.
Yep, it's the Rousseau Router Base Plate, for the grand sum of $8.99 at Woodcraft. Looks to be the same one as Klingspor's for $44. Woodpeckers has one for $120 that has more snap in parts that will fit more sizes of router bits, but I have no problems with the one I have. Unscrew the Base plate on your router and replace with the Rousseau. Might need to drill and countersink a hole or two. Instructions with the plate will show you all you need to know for installation. And buy a remote shutoff for the router, so you can turn it on and off without having to reach under the table.
Oops, I lied. The $8.99 is for the centering kit. The Base Plate Insert (model 3509) itself is $56. Sorry about that. Maybe the Klingspor at $44 is a better deal. Anyway, except for my pricing mistake, the rest of what I said is workable.
I knew one of these "you don't need a lift" replies would come along sooner or later. There is no comparison between a real high-end router lift and a router mounted to a plate. Zero. There's a reason those lifts like JessEm and WP cost what they do. They're built like tanks to handle the heaviest loads without flexing. Try making a stick cut in a 1-3/4" door stile in one pass without one. Actually, don't try - it would be dangerous.
Besides that, the precision in the adjustment is in another league as well. Most, like the JessEm have a split nut on the lead screw that can be set for zero backlash. Even as it wears, you can reset it for no backlash.
There are many other advantages as well. The bottom line is, if your setup meets your needs, that's great. It wouldn't meet mine.
Well…the truth is that ya don't NEED a lift. Buy one if you want to, or if you are doing something that does indeed require one. I don't do house type doors, and if I did I'd use my shaper and not the router. I don't need a lift, and haven't for 20 years of woodworking.
And do we really benefit from your suggesting that folks with no router lift are to be held in contempt?
The verdict is in…. after 2 days of assembling this entire kit I am finally happy to say that the 1617 collet IS INDEED accessible from above the table during bit changes. NO idea why they would say that. Sure your lower jam-nut wrench will be tilted but do-able. However, the angle over time might compromise that jam-nut so I bought some offset wrenches and it's overkill. IT CAN BE DONE.
Why would Woodpeckers make that claim? Or sort of make that claim.. I've only seen it in the owners manual.
One other issue… a $1000+ router table set up and it turns out they no longer provide the bolts to mount the lift to the phenolic table? Woodpeckers as usual, is awesome and is sending out 4 because I asked. BUT they told me they no longer supply them because the lift itself is heavy enough? Anyone buying that?
At least for the PRL that is absolutely true. It weighs at least 25-30 lbs and will not move and does not need hold downs. Can't speak to the newer ones as the specs say that version 2 is only 14 lbs.
Again, I'm dealing with a JessEm, but when I first got it I assumed the weight of the lift and motor was enough and didn't screw it down on the table. What I found was that, yes, it's heavy enough that it doesn't budge during use, but the leveling screws were turning due to vibration and I was having to re-level it frequently. When I screwed it down tight, it apparently locked those because I haven't had to touch them for a couple of years now.
Again, I m dealing with a JessEm, but when I first got it I assumed the weight of the lift and motor was enough and didn t screw it down on the table. What I found was that, yes, it s heavy enough that it doesn t budge during use, but the leveling screws were turning due to vibration and I was having to re-level it frequently. When I screwed it down tight, it apparently locked those because I haven t had to touch them for a couple of years now.
Excellent point Rich! I guess mine is older and grungier in the leveling hole inserts so they don't move but if you add in the weight of the router and the fact that I'm using a table fashioned from wood I'll bet those screws make their own depression which is why I need to adjust periodically. Should probably put something metal under them.
I have 2 WP PRL V2 lifts with 7518 PC motors in them and do all of my bit changes above the table. I use one bent wrench and one straight and have no problems at all.
Just went to the Woodworkers show in St. Louis and purchased the table, stand. fence, micro adjuster and lift on impulse. Wish I had read this before going. I have 3, Bosch 1617's and do not want to change as all my jigs and accessories are set up for Bosch. If I remove the ring I can change the bit from the top but it is not what I would call good. I think the lift , fence and micro adjuster is top quality but they should have worked out a fix. I would think just the placement of the set screw for the block and or maybe a little longer blocks would work. Not an engineer but a farm boy who sometime must make thing work.
Just went to the Woodworkers show in St. Louis and purchased the table, stand. fence, micro adjuster and lift on impulse. Wish I had read this before going. I have 3, Bosch 1617 s and do not want to change as all my jigs and accessories are set up for Bosch. If I remove the ring I can change the bit from the top but it is not what I would call good. I think the lift , fence and micro adjuster is top quality but they should have worked out a fix. I would think just the placement of the set screw for the block and or maybe a little longer blocks would work. Not an engineer but a farm boy who sometime must make thing work.
So here's the deal.. I've been using my Woodpeckers lift and Bosch 1617 for about a year now. While you certainly do not have incredibly clear access the the lower nut on the router (smaller nut below the collet), it is possible to make the change.
I find it best to use a straight wrench, not the offset wrench (Which I thought would have worked better) but not the case for certain bits. You're going to want to own both straight and offset honestly which isn't that big of a deal.
The biggest challenge I've had is using very large bits like a cabinet raised panel, or even a tongue and groove set up. The problem lies in you can't have the red zero clearance plate on, or any plate for that matter, and STILL access that lower nut.. so what I do is put the circular zero clearance/throat plate in then put the bit in while the straight wrench is seated in place.. tighten it all up, and slide wrench out from under the throat plate. This is for ONLY large bits.
I will say this… This router set-up has such repeatability, and ability to be tweaked and locked, and offset and minutely adjusted with the thumbwheel I find that having a small issue with the wrench not fitting under larger bits to be worth the price of admission.
This lift, and fence system is incredible. Micro adjust is next for me.
Don't let it ruin your purchase. It could be worse I just found out my brand new Grizzly table saw has .015 deflection at the rear of the blade when raising and lowering it. Now that sucks because the workaround is such that you can't be assured of accuracy. This issue you have isn't bad, trust me. I'm literally making shaker cabinets as we speak tonight and it's just not that big of a deal.
Basically WP simply made the Claim that those routers were affected by the lift… They went to the extreme and trust me, they went over kill in saying they are NOT COMPATIBLE… They are compatible, just that lower nut is tough to reach, not impossible… I've NEVER had to remove my lift.
Talked to Woodpecker today and they had a suggestion that will work for me. I must say that Customer Service at Woodpecker is TOPS. The cost of most items had stopped me from purchasing in the past, But quality of the products are top of the line and CS is great. So I now know I will get what I pay for from Woodpecker. A Top Quality product backed up with Top Quality Customer Service.
Cecil Dean
Not sure what the confusion is. I have a 1617 in that lift and have no issues.
Related Threads
LumberJocks Woodworking Forum
2.5M posts
96K members
Since 2006
