JWSS-10LFR table saw
Forum topic by fisherdad posted 09-13-2018 11:35 PM 252 views 0 times favorited 5 replies Add to Favorites Watch
View fisherdad's profile
fisherdad
3 posts in 124 days
09-13-2018 11:35 PM
Can someone help me replace the lift/lower belt? I have the new belt in hand but am unsure how to replace it. Thanks
-- Jim in California
5 replies so far
View GR8HUNTER's profile
GR8HUNTER
5361 posts in 946 days
#1 posted 09-13-2018 11:57 PM
Changing Poly V-Belt
Make all machine adjustments or maintenance
with the machine unplugged from the power
source. Failure to comply may cause serious
injury!
1. Disconnect the machine from the power
source, unplug.
2. Lower the blade to its lowest point and tilt to
45°. This will allow easy access to the poly v-
belt.
3. Take the tension off of the belt (A, Fig. 51) by
lifting up on the motor.
4. Remove the belt from the arbor and motor
pulleys.
5. Replace the belt. The weight of the motor and
the torsion spring should apply enough tension
to the belt.
Changing the Transfer Belt
Referring to Figures 52 and 53:
source, unplug.
2. Remove the front panel (D) by unscrewing the
lock knob (A), pulling off the handwheel (B),
and removing five pan head screws© that
hold the front panel.
3. Remove bolt (F) and pivot assembly up to take
the tension off the belt. Take belt off the upper
pulley.
Remove nut (G) and pull off the
assembly.
4. Remove the screw and washer (H) that holds
the shaft (I) in place.
5. Loosen the two setscrews (J) that hold the
timing pulley in place.
6. Pull out the shaft far enough so that you can
remove the timing belt (K).
7. Replace with a new belt and reassemble.
8. Make sure timing pulleys are aligned and
tighten setscrews (J).
9. Make sure tension on the timing belt is enough
so that the belt does not slip. Tighten bolt (F).
fisherdad
3 posts in 124 days
#2 posted 09-14-2018 01:57 AM
GR8HUNTER…....are you refering to a Jet JWSS10LFR? I can find no figures past 41 and the parts are numbered, not lettered. This is my first post and maybe I’m doing something wrong. Where do I find the figures you refer to? Is there somewhere other than the owners manual?
GR8HUNTER
#3 posted 09-14-2018 02:15 AM
try this :<))
View Carl10's profile
Carl10
109 posts in 690 days
#4 posted 09-14-2018 02:00 PM
Are these the instructions you are looking for?
https://www.ereplacementparts.com/images/jet/JWSS-10LFR_(708770).pdf
Page 23.
Carl
fisherdad
3 posts in 124 days
#5 posted 09-14-2018 04:43 PM
GR8HUNTER & Carl10…...........Yes, this is exactly what I needed. Thanks to the both of you. I’ll go change my belt now, thanks again.
