Shop countertops
Forum topic by Sparks500 posted 09-13-2018 09:08 PM 644 views 0 times favorited 9 replies Add to Favorites Watch
View Sparks500's profile
Sparks500
207 posts in 569 days
09-13-2018 09:08 PM
I’m building a miter saw station and I have 4 30” base cabinets, two for each side. For the tops, Menards has 6’x24” workbench tops made out of particle board, which I’m going to edge with hardwood and top with tempered hardboard. I’d like to glue the hardboard down with something that could be reversed to replace them, what glue would work best?
-- A good day is any day that you're alive....
9 replies so far
View Redoak49's profile
Redoak49
3740 posts in 2227 days
#1 posted 09-13-2018 09:12 PM
I used a couple short counter sunk screws instead of glue. For finish I used shellac and then wax.
View mathguy1981's profile
mathguy1981
87 posts in 143 days
#2 posted 09-13-2018 09:39 PM
Don’t use glue. I’ve used hardboard as a “replaceable” top before, and used 1” countersunk screws, worked like a charm.
-- Two thumbs and counting
View Woodknack's profile
Woodknack
12465 posts in 2618 days
#3 posted 09-13-2018 11:43 PM
Hide glue. Ones of it’s qualities is that is can be reheated and the parts taken apart.
View WoodenDreams's profile
WoodenDreams
377 posts in 149 days
#4 posted 09-15-2018 08:37 AM
Counter sunk screws without glue may by your best option. But if you use glue, Hyde Glue is really the only glue that you can dismantle, just by using a heat gun. Also Hyde Glue will stick to Hyde glue. That’s where I got my 24”x8’ laminated bench top. but I use I as a gluing and clamping table. Easy to remove glue off the lamination.
View Planeman40's profile
Planeman40
1330 posts in 2999 days
#5 posted 09-15-2018 03:19 PM
Yep, keep the hardboard tops removable and I recommend polyurethane as a finish, not shellac. Shellac is a great finish, however it uses alcohol as a solvent. Should you ever drop or spill alcohol on it it will melt. Polyurethane is tougher and more resistant to solvents.
View bondogaposis's profile
bondogaposis
5151 posts in 2590 days
#6 posted 09-15-2018 09:34 PM
I guarantee that if you glue it, no matter what type of glue, you will never replace it. It would be far easier to make a new top than to try and separate a glued down top, even hide glue. Use screws, and then the top will be easily replaceable, if you are worried about dinging a chisel or a plane use brass screws.
-- Bondo Gaposis
View 000's profile
000
2859 posts in 1138 days
#7 posted 09-15-2018 09:39 PM
Use melamine, or cover any substrate (PB, MDF, Ply) with plastic laminate. (formica,etc…)
It will last years and years, you wont have to change it.
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#8 posted 09-15-2018 11:16 PM
+1 ^^
I have always preferred laminate (Formica) over hardboard. Much more durable than hardboard, doesn’t soak up liquids (like stains or paint), easily cleaned … and you can get whatever look you want, from marble/stone to wood/butcherblock, or just plain solids. Put down with contact cement, it will stay put – but is still relatively easy to replace decades down the road if needed.
Sparks500
#9 posted 09-16-2018 01:29 AM
Ok, I was going back and forth, all good suggestions by all of you, went with simple: sheet of MDF with an overlay of white hardboard. Didn’t even know they made white hardboard, and its in stock at HD. 10 bucks a sheet, with 18 for the MDF with a little hide glue around the edges.
Formica would be great, but, I like the idea off running a screw into the top to fasten something down temporarily and not worry about it.
plus, it follows my motto: Easy, cheap, and fast….
Thanks to all of you.
