Fixing an old saw vise with a broken table clamp
« back to Hand Tools forum
Forum topic by Brett posted 660 days ago 1009 views 0 times favorited 3 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 854 days
660 days ago
I bought an old saw vise that looks a little like this one:
Like the one pictured, mine is missing the flat, disk-like clamping surface at the end of the screw (which is present on this C-clamp):
This vise only cost me $2 at a flea market, so it’s not a big deal if I can’t repair it, but I’m wondering if anyone has any suggestions on how I can replace the clamping disk so I can try to use the vise.
-- More tools, fewer machines.
3 replies so far
View Gregn's profile
Gregn
1643 posts in 1154 days
#1 posted 660 days ago
Considering you will use this vise on the same place on your bench for sharpening. I would just screw a steel plate underneath the bench where you’ll do your sharpening at.
I had one come off a harbor freight type F clamp and was able to pop it back on and crimp it enough to stay on. You might get one off a cheap clamp to put on it.
View Don W's profile
Don W
9967 posts in 738 days
#2 posted 659 days ago
I’m with Gregn on the steel plate idea. If that doesn’t work for you, you can make a new plate. Cut a piece off a steel rod. Drill a hole partialy through, peen it just enoought so it “snaps” over the end of your clamp screw. You may be able to peen it a bit more once its on.
View BarneyTomB's profile
BarneyTomB
28 posts in 689 days
#3 posted 658 days ago
How about using one of these? C-Clamp Pads
-- Profanity; The last refuge of the limited intellect.
