Skew chisel
« back to Woodturning forum
Forum topic by TDSpade posted 09-12-2018 06:55 AM 396 views 0 times favorited 7 replies Add to Favorites Watch
View TDSpade's profile
TDSpade
103 posts in 2536 days
09-12-2018 06:55 AM
As I am turning larger diameter vase sizes on my lathe, up to 6 inches for now. I was getting a few more catches with my one inch skew. I realized that I was running my planning cut too low and angle too steep. After adjusting for these problems I am good to go.
But I am wondering if should get a larger skew chisel for larger than 6 inch diameter spindle turnings? Any thoughts or recommendations would be appreciated.
-- For every expert, there is an equal and opposite expert.
7 replies so far
View Wildwood's profile
Wildwood
2408 posts in 2255 days
#1 posted 09-12-2018 10:05 AM
My Henry Taylor M2 1 1/4” skew bought back in the 1990’s a pleasure to use even though little shorter now. Over 1” skews are thicker and JMHO easier to use. With exception of Thompson tools would not look at exotic steel for a skew M2 HSS will work fine.
Although tool makers still make larger than 1” skews most vendors here may not stock them.
https://www.highlandwoodworking.com/crown1-14rollededgeskewchisel.aspx
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=104543&Category_Code=tools-pn-skewch
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=100012&Category_Code=tools-lacer
http://thompsonlathetools.com/product/1-14-skew/
-- Bill
TDSpade
#2 posted 09-13-2018 05:34 AM
Thanks Bill,
For the links and I think your right about bigger skews being better. I like that crown, I have 2 crown skews now. A 1 inch standard grind and ¾ inch with a rounded grind like that Lacer skew.
Terry
Wildwood
#3 posted 09-13-2018 07:11 PM
Might want to practice little with your new skew if have some wood available before tackling your vase. Would not use that skew if already started hollowing that vase. While larger skew will do everything a smaller kew can do they excel at long thick blanks.
-- Bill
TDSpade
#4 posted 09-14-2018 04:57 AM
I did order the 1¼ inch crown. But I’ll start a new vase from scratch. And I’ll take it easy to get a feel for it.
Terry
View Lazyman's profile
Lazyman
2397 posts in 1507 days
#5 posted 09-14-2018 11:03 AM
Once you get your new skew, you might want to consider reshaping one of them to a curved edge on it, that is unless you bought one like that. I haven’t tried it yet myself, but it is supposed to be less likely to dig-in. Here is a good article on modifying a skew to this profile.
TDSpade
#6 posted 09-14-2018 05:53 PM
My ¾ inch crown chisel is a radius grind. I do like it and use it mostly on wood that has a lot knots or grain changes.
https://www.amazon.com/gp/product/B001V9KOZA/ref=oh_aui_detailpage_o01_s01?ie=UTF8&psc=1
Terry
Wildwood
#7 posted 09-17-2018 10:28 AM
Wouldn’t change my new skew to radius until got used to it if at all.
Raffin introduced me to he radius (round) skew back then, but he uses both regular skew and his signature skew. Then came Lacer and now Glenn Lucas witrh their signature skews.
Which is better, conventional or radius, or straight (square) bevel on a skew? Depends upon the turner and personal preference see video below. Best thing tool manufacturers did was put a rolled edge on sides of skew at the factory. Had to take my first skews to the grinder, to put rolled edge on sides of the skews. Back then rolled all four sides at the grinder.
Both Raffin & Lacer have made videoss and written article explaining how to modify your skew and use the tool.
https://www.popularwoodworking.com/techniques/reshaping-the-skew-chisel/
Skew bevels & angles varieties:
https://www.youtube.com/watch?v=YFlZyGKYro4
Bottom line is learn to use the tool before changing!
-- Bill
