Jointing and planing SYP 2x4s for a workbench top?
« back to Hand Tools forum
Forum topic by Brett posted 655 days ago 1040 views 0 times favorited 3 replies Add to Favorites Watch
View Brett's profile
Brett
603 posts in 849 days
655 days ago
I’m considering building a new benchtop out of Southern Yellow Pine 2×4s to replace the current MDF surface. How necessary is it flatten the 2×4s before gluing them together? Can I just buy straight boards and glue them together, or do I need to beg/borrow/steal a jointer and planer to dimension them properly first?
-- More tools, fewer machines.
3 replies so far
View DYankee's profile
DYankee
2777 posts in 728 days
#1 posted 655 days ago
I recently made a workbence top out of 2×6s myself using my tablesaw. I resawed each 2×6 in half and then trued up each edge on the tablesaw all to the same dimension (as I recall about 1-5/8×2-1/2). I then glued these up using cauls. The first glue up was two each (1-2, 3-4, 5-6, ....) then I doubled those up (1-4, 5-8,...) until I had them all glued. I paid real close attention ensuring at least one side (the top) glued up as flat/true as I could get it. To finish it I stuck some self-adhesive sandpaper to one side of a length of 2×4 (that I trued up on theTS) that was a bit longer than the top was wide. I then did the pencil squiggle thing, marking all over the top, and then sanded until the lines were all gone. By using the 2×4 sanding block longer than the overall width, it sanded it down true/flat across the whole length.
If your surface after gluing is too much out of flat/true to go directly to sandpaper, you could use a joining plane first.
-- Shameless - Winner of two Stumpy Nubs Awards
View yrob's profile
yrob
265 posts in 1818 days
#2 posted 637 days ago
You will have to joint the boards. 2×4s come with a rounded edge and are not ready to glue. You can do that pretty easily with a jointer plane. Once you have a good edge, you can glue them together in groups of 3 or 4. Once its dry, you again use your hand plane jointer to flatten the surface. You repeat for 2 or 3 groups and then glue these together and do a final planing.
-- Yves
