Band saw blade wobble
Forum topic by SharkeysEnd posted 09-10-2018 09:32 PM 476 views 0 times favorited 26 replies Add to Favorites Watch
View SharkeysEnd's profile
SharkeysEnd
33 posts in 35 days
09-10-2018 09:32 PM
Topic tags/keywords: band saw wobble
Hi all. I got a band saw from CL a while ago, and after changing the blade and tuning it up (per Alex Snodgrass’ tutorial), the blade moves side-to-side during operation. I tried increasing the tension, but that didn’t do it.
I capture some slo-mo video of it.
View on YouTube
I cleaned off the rubber as best I could. It’s as though the wheel is dented at one point. Is this a common occurrence? Do you think I need new wheels?
It’s a King Machinery 14” band saw. I’ll post a photo in a moment.
Thanks.
-- "Many folk like to know beforehand what is to be set on the table; but those who have laboured to prepare the feast like to keep their secret; for wonder makes the words of praise louder." -Gandalf
26 replies so far
SharkeysEnd
33 posts in 35 days
#1 posted 09-10-2018 09:34 PM
Here’s the model information
View Steve's profile
Steve
605 posts in 700 days
#2 posted 09-10-2018 09:42 PM
if you put the old blade back on, does it do the same thing?
View Oldtool's profile
Oldtool
2717 posts in 2308 days
#3 posted 09-10-2018 10:01 PM
I’m no expert, but it appears to me that the blade is loose ( insufficient tension ) and the guides are completely out all the way.
As Steve mentioned, with a different blade does it still occur? Both easy and fast, check the blade first.
Maybe the tension spring is weak, are you sure the blade is under tension?, many magazine articles state not to trust the machine tension indicator, and to use a setting higher up on the scale. Some go so far as to suggest tensioning until the blade produces a note when plucked.
Check you wheels for balance.
That’s about all I got, good luck.
-- "I am a firm believer in the people. If given the truth, they can be depended upon to meet any national crisis. The point is to bring them the real facts." - Abraham Lincoln
View Kazooman's profile
Kazooman
1115 posts in 2070 days
#4 posted 09-10-2018 10:12 PM
Ditto to the above. Put the guides where they should be. Don’t trust the tension indicator. You can easily test for a bent wheel, a wobbling wheel (loose or bad bearing), or a flat spot on the tires by holding a pencil or something like that firmly against the frame with the point near the wheel and rotate the wheel by hand. The ideal way would be with a dial indicator but you don’t need to get that fancy.
View CWWoodworking's profile
CWWoodworking
83 posts in 297 days
#5 posted 09-10-2018 10:57 PM
I don’t think it’s tension.
Check blade
Check tires
Check out Carter bandsaw guides ASAP.
I buy about 10 blades a month. Would be twice that without the Carter guides.
View Firewood's profile
Firewood
440 posts in 1752 days
#6 posted 09-11-2018 02:57 AM
All good points to check. One last thing, did you verify the blade isn’t mounted upside down?
-- Mike - Waukesha, WI
SharkeysEnd
33 posts in 35 days
#7 posted 09-11-2018 01:46 PM
My apologies – when I posted yesterday evening, I didn’t know that I was going to get involved in something that took my attention for the rest of the night.
Thank you all for the replies. Let’s see…
- Steve
That is a very good question, and one of the first things I will try when I have a few minutes this afternoon. The previous owner had a metal cutting blade on it, which I still have. I also bought two other new blades that I can try.
I have it tightened almost as far as it will go. As I mentioned, I tuned the saw based on the Alex Snodgrass method, i.e. tapping the blade with my finger only moves it about 1/8”. I don’t think this machine has a tension indicator and I wouldn’t use it if it does. And the guides are out because the blade moves so much. It was my understanding that a a properly tuned saw blade wouldn’t have that lateral movement, and that the blade shouldn’t touch the guides under normal operation (when not cutting something).
I was at a bit of a loss when ordering blades for this thing. I ordered them from Sawblade.com, but their wizard doesn’t have my model. Since it’s a 14” saw, I ordered the standard 93-1/2” blades, but perhaps they should be a little shorter. Like I said, it’s tightened almost as far as it will go.
I’m going to try that while I’m switching the blades. I do have a dial indicator, so that might be enlightening.
It’s most certainly not installed backwards.
Thanks again for the replies. I’ll check the tires and other blade during lunch.
View BroncoBrian's profile
BroncoBrian
754 posts in 2076 days
#8 posted 09-11-2018 02:33 PM
I agree the guides are important, but they should not touch the blade when you are not cutting, so installed or not, that wobble is not ok.
Does the machine wobble like it is out of balance?
Looks like a blade tension issue, maybe you need to downsize?
test the old blade, then if it is ok, lay them one each other if possible and check the size.
-- I'd like to see a forklift lift a crate of forks. It'd be so damn literal!
View DrDirt's profile
DrDirt
4451 posts in 3860 days
#9 posted 09-11-2018 03:32 PM
Open the door and spin the wheel
You will know if it is the wheel or the blade
I would suspect a screwed up/damaged or mismounted tire. Or a blown out bearing
You simply cannot stomp and kink a blade enoug to move THAT much under full tension
Womething is wrong with the wheel
Is it noisy while running?
SharkeysEnd
33 posts in 35 days
#10 posted 09-11-2018 05:58 PM
Is this normal?
I put a dial indicator on the tires (before removing the rubber). The top wheel had about 0.007” of variance, and the bottom wheel had about 0.015”. So I took the rubber off the bottom one in case there was gunk underneath and saw those holes. I’m not sure if that is standard practice to balance it.
I see new polyurethane tiresUS!-1 on eBay for the King Machinery. The price seems reasonable.
Then I saw a listing for blades for the KM band saw, and they were 92 1/2”. So I probably erred in ordering the 93 1/2” ones, and so tension might still be the issue.
At this point I’m into the thing for $100 plus the cost of three blades. I’m not sure how much more I want to dump into it. I probably should have waited and found a more common brand. But I’d been looking for about a month and quite simply got impatient.
Thanks as always for the responses. I’m such a noob.
BroncoBrian
#11 posted 09-11-2018 07:07 PM
I don’t know if that is normal or not. I have not seen it, but who knows. If you think you might be off an inch, that is A LOT.
Can you verify by comparing the old and new blade?
You should be able to have the blade shortened.
View AHuxley's profile
AHuxley
752 posts in 3439 days
#12 posted 09-11-2018 10:35 PM
Is this normal?
- SharkeysEnd
Drilling wheels is normal practice to balance them. It depends on the casting where manufacturers drill them but they usually drill them in a non-visible area. You also want to drill as far from the center as possible because that requires less material to be removed.
When I slowed down your video, even more, it appears that it may be a tension issue since it looks like high amplitude flutter that is not following a wheel or blade revolution cycle. If the longer blade is forcing you to bottom out your tension adjustment that may be the root of the issue.
BTW forget the comments about guides, that is clearly NOT the cause of this problem and you did the absolute correct thing by showing the blade movement with the guides backed off. While setting the guides properly would alleviate some of the symptom it would do nothing to identify or cure the actual problem.
View Bob Kassmeyer's profile
Bob Kassmeyer
227 posts in 3043 days
#13 posted 09-12-2018 12:06 AM
Hi, I have a Grizzly G0555, it comes stock with a 92.5-inch blade but you can convert it to a 93.5-inch blade doing something with the tensioning adjustment. I don’t remember what it was, it’s been a long time, but it was not too difficult. I think maybe you could look in one of the manuals online at Grizzly.
-- Bob Kassmeyer, Nebraska
BroncoBrian
#14 posted 09-12-2018 12:44 AM
- AHuxley
Well said.
If your blade was not wobbling because the guides were in place, that would be masking a more serious issue.
View Lazyman's profile
Lazyman
2387 posts in 1505 days
#15 posted 09-12-2018 12:52 AM
At this point I m into the thing for $100 plus the cost of three blades. I m not sure how much more I want to dump into it. I probably should have waited and found a more common brand. But I d been looking for about a month and quite simply got impatient.
Thanks as always for the responses. I m such a noob.
- SharkeysEnd
Before I saw this post, my first thought was that the blade was too long so was going to suggest you compare the length to the old blade.
You could find a local shop to cut and braze your blades to the correct size or you could try to do it yourself. There are several YouTube videos on doing it yourself if you are so inclined. I’ve never tried it myself but this one makes it look pretty easy.
