Long Miter Joint Spline......What wood to use?
Forum topic by Angela posted 08-02-2011 03:42 PM 4440 views 0 times favorited 7 replies Add to Favorites Watch
View Angela's profile
Angela
205 posts in 2802 days
08-02-2011 03:42 PM
Topic tags/keywords: question spline miter joint table saw joining
I’m making at TV stand and I’ve miter the corners. The corners are not set to 45 degrees, instead they vary. I’m going to add splines to the joints. I read the splines are suppose to be snug-fitting but isn’t there a problem with expanding and contracting?
Will any wood do?
Thanks
Angela
-- www.WoodWorkersWebsite.com - Helping other woodworker's
7 replies so far
View Blair Helgason's profile
Blair Helgason
169 posts in 3320 days
#1 posted 08-02-2011 05:42 PM
I’m in the exact same situation. I too have heard that if the pieces are small, like splines tend to be, wood movement isn’t as much of an issue. I’ll probably go with maple or oak. Thanks for putting the question out there.
Also, I’m not sure if you know about Matt’s Basement Workshop but he did a nice process video of a Walnut Buffet where he mitred all of the corners. I think he used biscuits, not sure though, here’s the link:
http://mattsbasementworkshop.com/451-walnut-buffet-pt-1/
-- Blair
View KayBee's profile
KayBee
1083 posts in 3152 days
#2 posted 08-02-2011 07:15 PM
I’ve used hardboard for long splines in the past. No problems that I know of. They were shipped all over the country too.
-- Karen - a little bit of stupid goes a long way
Angela
#3 posted 08-02-2011 08:11 PM
Thanks for your help and thoughts everyone. Also thanks for the link. I looked at the site and I’m going to spend more time looking on his web site; it seems like he has some good info on it.
I was wondering about hardboard, the splines will be about 19” long, but I’d never heard of anyone using hardboard so I’m glad you mentioned it.
Angela
KayBee
#4 posted 08-02-2011 08:33 PM
I think the longest were about 8’. They went in a bunch of high end clothing stores shelving units. Ended up shipped all over the country, with different humidity, sat in unheated warehouses and generally mistreated. The installers said they were good.
Blair Helgason
#5 posted 08-03-2011 04:35 PM
Good call on the hardboard, I’ve used it before for placeholder splines until I made the real ones, almost forgot to replace them.
Hardboard seems a lot easier than milling a bunch of strips, especially if you don’t have much scrap hardwood around like me.
-- Blair
Angela
#6 posted 08-05-2011 01:43 AM
If you read my blog you’ll see I had a problem with the plywood so I have some extra pieces already cut. I’ll glue them up with hardboard and see how it works and about the glue expansion.
Angela
#7 posted 08-06-2011 02:23 AM
I just wanted to update anyone regarding the use of hardboard for splines. I’ve been researching the net and have found numerous articles and woodworking plans that recommend using hardboard for longer miter joints.
Here’s a couple of quotes to sum up what I found.
Splined Edge-to-Edge Joint
This is a variation of a biscuit joint. Instead of using numerous smaller biscuits, splines are essentially a single long biscuit used to align the two pieces. The spline is a piece of plywood or hardboard that is placed in a slots that are cut in the adjoining edges. These slots can be stopped so they do not show if the ends are to be exposed. One thing to keep in mind is to ensure the spline is slightly narrower than the depth of the slot. Making the spline exactly the depth of the slot can lead to splitting of the wood as the surrounding wood shrinks, but the hardboard spline does not . A gap of 1/32 (1/64th on either slot) is sufficient to prevent this problem.
Shop Notes
For Long Miters. A “capped” plywood (upper) or a hardboard (lower) spline work well forlong miter joints.
I also found a great article regarding splines in general from Shop Notes
Thanks everyone
Angela
