Help with tiger maple
Forum topic by therookie posted 08-02-2011 12:02 AM 3088 views 10 times favorited 11 replies Add to Favorites Watch
View therookie's profile
therookie
887 posts in 2825 days
08-02-2011 12:02 AM
Does anyone know what type of finish that charles Neil uses on tiger maple to make the figure pop I know he uses trans tint dyes but where can I get dye for a good price.
-- http://aewoodworks.webs.com
11 replies so far
View Dez's profile
Dez
1166 posts in 4075 days
#1 posted 08-02-2011 03:51 AM
Drop him an email, I am sure he would be more than happy to help!
-- Folly ever comes cloaked in opportunity!
4986 posts in 2491 days
#2 posted 08-02-2011 05:37 PM
Jeff Jewitt sells the Trans Tint products from his website HomeStead Finishing Products
View CharlesNeil's profile
CharlesNeil
2399 posts in 3868 days
#3 posted 08-02-2011 11:01 PM
so lets ask him,,, glad to help., tell me exactly what you you want to know,, and I’ll see if i can get him to answer,,:) I know him well haha,..
therookie
#4 posted 08-03-2011 02:52 AM
Hey Mr. Neil, I was just wondering the dye color that you use to bring out the colors I have just gotton tiger maple from Skip at GHH for my music Stand and want to finish the final stand right and make it look good. After I build a prototype out of poplar of course.
CharlesNeil
#5 posted 08-03-2011 02:40 PM
typically I use the General Finishes dyes, the most poplar color is a mix of 1 pt light brown ,1/2 part orange and 1/2 part water. we call this New England maple as it looks like the slight orange tinted maples of the old shakers, and as stated its our most chosen color on Tiger maple, and of course you can adjust to taste, but the other thing we do is what we call trace coating, meaning I will apply the dye when I am ready to sand, this will show me any glue, or other imperfections, once I have sanded to 120 I apply another coat, but remember the curl in the tiger maple is a softer grain so it will absorb the dye more so than the harder grain, so dont expect to remove all the dye from the curl, and we really dont want to’ Once it is redyed at 120 , I sand to 180 , now the curl is really starting to show, then the final dye. what has happened is the curl now has 3 coats of dye and the harder surface has 1 , thus the curl is very well defined, you can experiment also using a much darker color for the first and second dye , I have even used a diluted ( 50 %) black… experimenting with base color dyes for curl enhancement, you will find some interesting effects can be achieved,,, this only works on woods that have defined figure like tiger maple and quilted maple and so forth, Once the dye has dried I use some General Finishes seal a cell to “pop the curl”, what this does is soaks into the softer curl and begins to “fill’ it with a oil, I usually use 2 coats, this then creates a prism effect to give the curl depth and “pop”.. many use BLO, I hate the stuff, while it does well in enhancing the grain, it just nevers dries to a very strong finish, and now days it seems to be worse,, so I prefer the seal a cell, because it dries quickly and is much advanced in durability, once dry I top coat , for a oil finish I use GF arm R seal , but for me , it is usually a sprayed water base finish in a satin sheen…. hope this answers and helps if not ask away
therookie
#6 posted 08-04-2011 02:10 AM
This helps a ton where do you get the general finishes and arm-R-seal. Thanks, Adam
View Dusty56's profile
Dusty56
11819 posts in 3686 days
#7 posted 08-04-2011 02:53 AM
I know WoodCraft sells those items : )
therookie
#8 posted 08-04-2011 11:24 AM
Thanks dusty
View tyskkvinna's profile
tyskkvinna
1310 posts in 2984 days
#9 posted 08-04-2011 03:34 PM
Hey, thanks for this! I have a lot of heavily figured maple and it would fun to try this out on some of it.
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
View Cosmicsniper's profile
Cosmicsniper
2202 posts in 3156 days
#10 posted 08-04-2011 04:56 PM
Here is a great thread a month or two ago that really explores some of the dye dynamics and techniques the Charles described, at least in part.
http://lumberjocks.com/topics/27475
BTW, I think its easy to outthink yourself with tiger maple. You can pop the grain pretty spectacularly by wiping on an oil or some shellac (I like the Zinnser Seal Coat for this). But the sanding step is key.
You might want to checkout Marc’s video on this subject here…
http://thewoodwhisperer.com/episode-32-pop-goes-the-maple/
-- jay, www.allaboutastro.com
CharlesNeil
#11 posted 08-04-2011 05:13 PM
I agree the seal coat pops grain well and I use it often, its as good as an oil, however, if you plan to use an oil finish, it will seal off any absorbtion of the top coat oil,, I use seal coat usually under a film finsh like lacquer, or water base, ...
