Why do I need a buffing wheel for my lathe?
Forum topic by Alan S posted 08-01-2011 11:57 PM 2487 views 0 times favorited 8 replies Add to Favorites Watch
View Alan S's profile
Alan S
181 posts in 3251 days
08-01-2011 11:57 PM
Topic tags/keywords: turning finishing
Everyone has the 3 wheel buffing systems for sale for you to use on your lathe. I would assume these are meant for small LATHE projects. Why can’t I just leave my workpiece on the lathe, and use a rag with buffing compound on the piece while it’s spinning to do the same thing? Thanks!
8 replies so far
View David Kirtley's profile
David Kirtley
1286 posts in 2932 days
#1 posted 08-02-2011 12:58 AM
It is more of a point of you already have a motor sitting there on the lathe. Why have another one for a buffer?
It is getting multiple uses of the same machinery. The best combination I have seen are the ones that have a disk sander on the outboard side of the spindle. You can turn to one side and sharpen a chisel when it gets dull.
-- Woodworking shouldn't cost a fortune:
16273 posts in 4152 days
#2 posted 08-02-2011 01:43 AM
I buff all sorts of stuff on mine….. not just turnings. And since you have all three wheels right there, you can go through the progression very quickly.
View Keith Fenton's profile
Keith Fenton
328 posts in 2854 days
#3 posted 08-02-2011 01:48 AM
I just put a big bolt through the buffing wheel and mount it in my chuck. I only use 1 ultra fine wheel though so I don’t need to keep swapping wheels.
-- Scroll saw patterns @
View crank49's profile
4030 posts in 2905 days
#4 posted 08-02-2011 02:20 AM
Keith, you don’t use the same wheel for more than one compound do you?
Keith Fenton
#5 posted 08-02-2011 02:25 AM
No, that wouldn’t work. I only use the buffing wheel for the last and finest polishing.
View Jim Jakosh's profile
Jim Jakosh
20169 posts in 3039 days
#6 posted 09-19-2013 12:15 AM
I just bought 3 wheels from Beall. They came with the Tripoli , white diamond and Carnuba wax and a video on buffing and threading.
I usually use EEE polish and Shellawax friction polish in the lathe when the part is fully round. But lately I have been turning crotches and irregular pieces and for that I’ll need the buffing wheels if I want to get to a 2000 or better finish. I also have a corian project that has wood embedded in it and it is irregular so that will need to be done on the buffer. I’m in the process of making the mount arbor for it so I can try them out. I’m going to use them one at a time instead of the 3 in a row.
Cheers, Jim
View RussellAP's profile
3103 posts in 2220 days
#7 posted 09-19-2013 12:40 AM
When you spin the work, everything leaves lines. With the buffing wheel you can vary the way the work contacts the buffer. I prefer a small buffer on a drill and leave the work on the lathe. I can randomize and speed things up a bit. Works for sanding too, but not quite as easy to get into tight places.
View Underdog's profile
1058 posts in 1969 days
#8 posted 09-19-2013 01:21 AM
I bought several buffing wheels, and all the different grits of compound for less than $20 at Sears.
I then turned several mandrels for the buffing wheels out of some scrap poplar, and mounted the wheels on them.
I can now just chuck up which one I want and buff pens, bowls or whatever.
And I can put up with a certain vendor’s snide remarks about how cheap I am… because I don’t really need to buff that much stuff, and the Sears stuff has held up just fine, and I’m not out the $$$ for something too expensive to justify for the amount I use it.
Oh. And you don’t really wanna use a rag to apply compound to a spinning object. Too much chance you’ll get dragged in and injured. Use a good quality paper towel instead.
-- "woodworker with an asterisk"
