feed rollers not moving on 22-580 planer
Forum topic by patnbill posted 08-02-2011 11:17 AM 1951 views 0 times favorited 5 replies Add to Favorites Watch
View patnbill's profile
patnbill
3 posts in 2399 days
08-02-2011 11:17 AM
While using my 22-580 planer, the feed rollers stopped feeding but the motor was still running. When I removed the belt cover, I found the belt frayed and broken. I ordered the delta part # 22-563 and replaced the belt. After putting everything back together and turning it on, the feed rollers still don’t move. Anybody have an idea on what else I need to do?
5 replies so far
View ajosephg's profile
ajosephg
1880 posts in 3470 days
#1 posted 08-02-2011 02:10 PM
On the side opposite the belt there is a gear box, sprockets, and link chains. Look over there and you’ll find the problem. I’d guess that one of the sprockets broke.
-- Joe
patnbill
#2 posted 08-02-2011 03:08 PM
Thank you so much. I’ll take a look on the other side.
View teejk's profile
teejk
1215 posts in 2593 days
#3 posted 08-02-2011 04:29 PM
and make sure you are “in gear” (there is “neutral” spot on the speed set lever). as I recall the instructions say only to change speeds when the machine is running.
patnbill
#4 posted 08-02-2011 07:15 PM
Got it. When I opened up the other side, the sprockets and chains were all in place and looking good. I plugged it up, turned it on, reached around and changed speed. That was it. Apparently during the process of changing the belt, I moved that lever. Thank you so much for the help. You guys are the best!!
Patsy
ajosephg
#5 posted 08-02-2011 09:13 PM
Oh! What a relief!!!
-- Joe
