Unloading 350lb saw from back of Truck
Forum topic by bgilb posted 09-07-2018 05:34 PM 1892 views 0 times favorited 39 replies Add to Favorites Watch
View bgilb's profile
bgilb
73 posts in 3297 days
09-07-2018 05:34 PM
So looks like SAIA isn’t going to deliver my G0771z saw, so I’m going to probably pick it up at the terminal. I have a truck so loading is no problem. Once I get home not really sure how to unload? I have some 2×4s and plywood. Unfortunately I don’t have anyone that could help me (unless I stopped by Home Depot to find day labor lol)
I was thinking cut a small notch in the 2×4 so it will stay on the truck bed. Strap the 2×4s to my towing hitch so they don’t slide or anything.
39 replies so far
View MrUnix's profile
MrUnix
7106 posts in 2437 days
#1 posted 09-07-2018 05:58 PM
2x’s and gravity are all you need – nothing special required. 350lbs is not a lot of weight – I’ve unloaded machines much heavier by myself using the same ramp method.
View John Smith's profile
John Smith
1552 posts in 401 days
#2 posted 09-07-2018 06:11 PM
and once on the concrete, you can roll it around on
a few pieces of PVC pipe with little effort.
-- I started out with nothing in life ~ and still have most of it left.
View GR8HUNTER's profile
GR8HUNTER
5381 posts in 951 days
#3 posted 09-07-2018 06:14 PM
MY NEIGHBOR has a bobcat with forks I say hey buddy what beer do you drink these days :<))
View Steve's profile
Steve
821 posts in 821 days
#4 posted 09-07-2018 06:22 PM
you might want to think about opening the box there and inspecting everything before you take possession of it.
View HokieKen's profile
HokieKen
7568 posts in 1377 days
#5 posted 09-07-2018 06:50 PM
Your method with the tubafors will work fine. It’s not so effective at loading but works well when gravity is in your favor ;-) You can also consider unpacking everything you can from the box before you unload the crate.
-- Kenny, SW VA, Go Hokies!!!
View ChefHDAN's profile
ChefHDAN
1230 posts in 3088 days
#6 posted 09-07-2018 07:36 PM
- HokieKen
+1
View BroncoBrian's profile
BroncoBrian
875 posts in 2197 days
#7 posted 09-07-2018 07:38 PM
2x s and gravity are all you need – nothing special required. 350lbs is not a lot of weight – I ve unloaded machines much heavier by myself using the same ramp method.
- MrUnix
Yep, you and one person should be able to let it down just fine. If you have to, open and remove the cast iron wings. Mine was a little over 400 lbs and I was able to get it unloaded and upright with one person’s help in a few minutes.
-- A severed foot is the ultimate stocking stuffer.
bgilb
#8 posted 09-07-2018 10:30 PM
Stupid saia said I can’t pick it up even though it’s been at the terminal for the entire day because someone has to authorize it. So now I have to wait until Monday!
View BFamous's profile
BFamous
227 posts in 359 days
#9 posted 09-07-2018 10:56 PM
pick yourself up some ramp ends from Lowe's or HD
You attach the to the end of a 2xwhatever you want… Theres rubber on the bottom to keep them from slipping and the lip is much easier to hop over than the end of a notched 2×4.
When I moved all if my equipment I used these with 2×12s, and also nailed a 2×4 on the outside edge of each 2×12 to provide a lip to keep my stuff from accidentally rolling off the side of the ramps. Having the width of the 2×12 was nice (especially for the 3 wheeled Delta table saw), and I was never once worried about something bad happening to my stuff…
-- Brian Famous :: Charlotte, NC :: http://www.FamousArtisan.com
View Dave Polaschek's profile
Dave Polaschek
3079 posts in 821 days
#10 posted 09-08-2018 12:01 AM
If you’ve got a neighbor with a motorcycle, ask if he has a ramp. My motorcycle ramp will carry 800 pounds, and extends far enough from the truck that I walked a bandsaw on an appliance dolly up with no troubles. The ramp is 2’ wide or so, so there was plenty of room.
Down is easy compared to up.
-- Dave - Minneapolis
View waho6o9's profile
waho6o9
8539 posts in 2815 days
#11 posted 09-08-2018 12:07 AM
View Andre's profile
Andre
2364 posts in 2044 days
#12 posted 09-08-2018 12:08 AM
Come on it is a Grizzly! Open end gate, put er in reverse, hit gas then brakes! Simple, off loaded!
Maybe check blade alignment after you have it unpacked?
View Desert_Woodworker's profile
Desert_Woodworker
1673 posts in 1453 days
#13 posted 09-08-2018 12:36 AM
remember to remove the tailgate before unloading.
-- Desert_Woodworker
Desert_Woodworker
#14 posted 09-08-2018 12:36 AM
- waho6o9
+1 and other option-
bgilb
#15 posted 09-08-2018 12:38 AM
What does removing the tailgate do?
showing 1 through 15 of 39 replies
