Standards for a Mitre Saw
Forum topic by deusprogrammer posted 663 days ago 494 views 0 times favorited 3 replies Add to Favorites Watch
View deusprogrammer's profile
deusprogrammer
9 posts in 684 days
663 days ago
I just wanted to ask…is it normal to have to use a set of standards for a mitre saw? My Skil 12” Compound Mitre saw doesn’t seem to cut the 45 degree angles very accurately unless I use a block I know is a perfect 45 degree angle to line it up first. Is there a way on a Mitre Saw to adjust the stops or adjust the fence to make it perfectly 45 degrees? Or should I just continue playing it safe and using my standards? I also expect to catch flak for using Skil brand anything.
3 replies so far
View Loren's profile
4898 posts in 1820 days
#1 posted 663 days ago
Often the bevel setting can’t be relied on – you have to set the stop for
a perfect 45. The miters should be dead-on.
Higher quality saws have positive shot pin metal-to-metal type arrangement
for the miter settings to common angles. On the saws I’ve owned,
the bevel always had to be fudged.
View StephenO's profile
StephenO
37 posts in 718 days
#2 posted 663 days ago
Most miter saws can be calibrated by adjusting the position of the scale/stops.
-- -Steve, Seattle
View Sawkerf's profile
Sawkerf
1776 posts in 1241 days
#3 posted 663 days ago
If your back fence can be adjusted (and most can), let your saw “snap in” at 45*, then use your standard to set the back fence. That’s how I do both of my miter saws.
