Bowl gouge dulling quickly
« back to Woodturning forum
Forum topic by JoshNZ posted 09-05-2018 08:33 AM 907 views 0 times favorited 16 replies Add to Favorites Watch
View JoshNZ's profile
JoshNZ
127 posts in 1310 days
09-05-2018 08:33 AM
Topic tags/keywords: sharpening
Just wondering if anyone can shed any light on why my bowl gouge dulls so quickly when hollowing out. I read something in a wood turning book last week about a guy saying he sharpened once or twice a day in a production workshop =/. Sometimes I’m lucky to get two passes before im really needing to push on it.
I’m guessing my problem is that I’m scraping the wings as the photo shows. Ive tried varying the openness of the flute and nothing seems to help. Is this just not a suitable grind to be hollowing with or am I doing something else wrong? It’s a 1/2”, U-flute, HSS, and quite a swept in fingernail grind.
It’s lovely to use right off the grinder, in my position shown I get a nice hissing with good shàvings. But it doesn’t last long. Wood is wet walnut.
Thanks!
16 replies so far
View Wildwood's profile
Wildwood
2531 posts in 2376 days
#1 posted 09-05-2018 12:19 PM
What brand bowl gouge do you have? Do you have the same problem with other wood species?
Looking a gouge picture looks like you are sharpening correctly.
-- Bill
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1971 days
#2 posted 09-05-2018 01:57 PM
I do a lot of Mesquite, and a bunch of Palo Verde, both local desert woods. From one tree, I can turn maybe 5 large plates before sharpening. Wood from another tree, sometimes I have to sharpen after 2-3 passes. I’ve heard that it depends on how much silica the wood sucks up while the tree is alive. My gouges are Thompson’s. ........... Jerry (in Tucson)
View Kirk650's profile
Kirk650
585 posts in 989 days
#3 posted 09-05-2018 04:16 PM
I assume you have HSS gouges. As for rapid dulling, the first thing that comes to mind would be that you may be making a semi scraping cut rather than slicing.
View Aj2's profile
Aj2
1953 posts in 2039 days
#4 posted 09-05-2018 06:33 PM
This also seems weird to me. I don’t do much turning lately but when I did the edge on my bowl gouges lasted very long time. I used a Tormek to shape and sharpen.
Maybe your grinder is too course and the steel is getting to hot?
-- Aj
View Woodknack's profile
Woodknack
12469 posts in 2621 days
#5 posted 09-05-2018 07:22 PM
It can really only be 2 things, the steel isn’t very hard or the wood is full of an abrasive like silica. Change one variable and see what happens.
JoshNZ
#6 posted 09-06-2018 12:28 AM
The steel is HSS (so it says), it’s a fairly cheap set I got while I was in Canada. That said I was once stuck for a parting tool on my metal lathe and I formed one out of my round scraper from the same set and clamped it in the tool post. If it cut mild steel it should cut wet wood!
I tried some mangeo today a native NZ wood, still the same problem. Also tried a woodcut chisel with the replaceable hss tips, 3/8” and narrower flute, same problem across all so I think it must be my technique.
I’ve tried varying the flute angle as I said, I can’t see any way to present it to the cut that won’t make some of the edge scrape. The cut is clean because the last part of the edge is at a slicing angle but higher on the wing is definitely a more scraping angle. Is this normal?
The chisels are ground with a jig on a normal bench grinder fine grit wheel, I can touch the tip after the pass just barely. One or two strokes with 600grit out of the flute to remove the burr and then I get cutting, and it’s definitely sharp at that point.
Wildwood
#7 posted 09-06-2018 10:26 AM
Looking at shavings on the floor don’t think gouge is the problem. Already mentioned about same species of wood can be both blessing or curse. Bottom line once you start forcing the cut, time to re-sharpen your tool!
Bevel angles are a compromise depending upon bowl design. If go to page 13 of link will find good info on bevel angles and see what am talking about!
http://s12166.pcdn.co/wp-content/uploads/2015/09/Woodturning_Notes.pdf
You already discovered even cheap steel tools will cut cleanly if sharp! So when in doubt re-sharpen your tool (s)! High carbon, any variety of HSS, exotic steel tools won’t cut cleanly when dull.
Yes some bowl gouge bevel angles work better than others for different designs. Then again a degree or two won’t matter much. So once find one stay with it, or will end up wasting lot of steel at the grinder and not accomplish much!
-- Bill
Nubsnstubs
#8 posted 09-06-2018 02:25 PM
The steel is HSS (so it says), it s a fairly cheap set I got while I was in Canada. That said I was once stuck for a parting tool on my metal lathe and I formed one out of my round scraper from the same set and clamped it in the tool post. If it cut mild steel it should cut wet wood!
I ve tried varying the flute angle as I said, I can t see any way to present it to the cut that won t make some of the edge scrape. The cut is clean because the last part of the edge is at a slicing angle but higher on the wing is definitely a more scraping angle. Is this normal?
The chisels are ground with a jig on a normal bench grinder fine grit wheel, I can touch the tip after the pass just barely. One or two strokes with 600grit out of the flute to remove the burr and then I get cutting, and it s definitely sharp at that point.
- JoshNZ
Leaving the burr on the tool end is supposed to give a good cut until it wears off. Try turning with the burr on and see if it extends the turning time between grindings. ............... Jerry (in Tucson)
JoshNZ
#9 posted 09-07-2018 10:36 PM
Great little attachment thanks Bill I’ll read through that again.
I will try leaving the burr on the tool too. It is paper thin usually I can flex it over with my fingers I couldn’t imagine it making a difference.
I think I’m getting better results holding the flute more open. So that more of the edge is presented at a slicing angle and less at a scraping.
View LeeMills's profile
LeeMills
629 posts in 1542 days
#10 posted 09-08-2018 12:27 PM
I keep looking at pics 1 & 2 and can’t decide. This may not help at all but the tool should not dull that fast.
It appears you may be trying to cut (scrape) directly into the end grain by the “dust” shavings in pic 1.
About minute 5.5 Lyle shows hollowing with the push cut. Note he is cutting about 45° toward the headstock.
www.youtube.com/watch?v=1HF9IGdHCTA
JoshNZ
#11 posted 09-09-2018 12:10 AM
I keep referring back to that same video as well I learned a lot from Lyle’s stuff. He’s what prompted me to try opening the flute a lot more which helps a little.
It’s probably been a combination of cheap steel, scraping, and silica rich wood.
Let me ask you this how long would your edge last if you scraped a whole bowl?
Wildwood
#12 posted 09-09-2018 12:38 PM
So many things can determine how long a tool stays sharp, type of steel, wood species, how you hold the tool, bevel angle on that tool, whether using a push or pull cut, etc..
Nice video explaining shear scraping. Reed loves his scrapers but does use his gouges too!
https://www.youtube.com/watch?v=xeOhPqOsORs
Have to learn difference on what you are turning whether push or pull cut is better on the piece working on.
Mike almost the same info as Reed but worth a look!
https://www.youtube.com/watch?v=77Yyd7PGMCA
Tool buying advice:
https://www.youtube.com/watch?v=ZM4ak8ygzS4
Both Reed & Mike will talk about using scrapers inside a bowl and extending over the tool rest if pay attention heavy duty scrapers a must!
-- Bill
LeeMills
#13 posted 09-10-2018 12:41 AM
- JoshNZ
I’m going to assume you mean with a bowl gouge. I have only used a scrape or sheer scrape with a bowl gouge as the final cleanup. Your earlier comment on the burr being able to be easily bent is normally true with a bowl gouge;
with a scraper the angle is usually 70° or greater so there is a lot of steel even when the burr is gone in just a couple of minutes.
JoshNZ
#14 posted 09-14-2018 10:01 PM
I changed the profile of my gouge yesterday, taking on more of a V with a radius tip than a fat U like it was. Also increased the bevel angle a bit and I took more of the bevel off the wings so it’s not quite so swept in as it was and it has helped tremendously. I roughed a whole bowl with only one sharpen in between.
Will have to keep playing around I might purchase a Thompson gouge. Any idea what size I should be after, if I’m only going to have one at this stage and already have a 10mm and 1/2” (diameters not flute width) in other brands.
Cheers
View OSU55's profile
OSU55
2034 posts in 2230 days
#15 posted 09-16-2018 12:38 PM
Might not be time for an expensive Thompson yet. If you saw a big improvement with changing wing sweep and bevel angle, it tells me you have a long way to go yet in determining the sweep and bevel angles that work well. Better to grind up cheap tools while figuring this out vs expensive tools.
5/8” tool dia not flute is by far my most used bowl gouge size and is the only size I buy in expensive steel.
