Table Saw Wiring Question
Forum topic by Justin posted 07-31-2011 05:21 AM 2599 views 0 times favorited 25 replies Add to Favorites Watch
View Justin's profile
Justin
119 posts in 2966 days
07-31-2011 05:21 AM
Topic tags/keywords: question tablesaw
I am pretty sure I am going to order the 10 Inch Left Tilt 2 HP Table Saw from general but i got a question about the wiring for the motor. It says the motor is pre-wired 230 (2 HP, 115/230 V, 19.5/9.5 A). I currently only have 120 running in my shop so I will need to change the saw over from 230 to 115, from what I gather all you need to do is change a few connections inside the saw and change the plug. Is that all you have to do or am i misinformed? and is this something I can do my self with some knowledge of electrical.
25 replies so far
View Toolz's profile
Toolz
1004 posts in 3740 days
#1 posted 07-31-2011 01:05 PM
Justin, I’m not sure about “General” but most saws have wiring diagrams in the manual that show you exactly what you have to do to change from 230 to 115.
-- Larry "Work like a Captain but Play like a Pirate!"
View Howie's profile
Howie
2656 posts in 2920 days
#2 posted 07-31-2011 01:44 PM
Like Toolz said, look at the manual or inside the connection cap on the motor. It’s not hard, just a couple of connections. Change the plug and you are in business. Save the plug in case you ever want to go back to 220.
-- Life is good.
TopamaxSurvivor
18269 posts in 3673 days
#3 posted 07-31-2011 09:04 PM
Your garage circuit may not start that saw. The general purpose circuit is usually 15 amp and that one draws 19.5. It may take up to a 40 or 50 amp breaker to start it.
View gfadvm's profile
gfadvm
14940 posts in 2687 days
#4 posted 08-01-2011 04:29 AM
I dont know about General but Grizzly will prewire their saws for 110 or 220. Just tell them which you want when you order. Talk to the service guys, not the order desk.
View Grandpa's profile
Grandpa
3259 posts in 2673 days
#5 posted 08-01-2011 04:48 AM
Elizabeth has a blog on this that was posted today. She changed her bandsaw. She has photos and costs.
View Manitario's profile
Manitario
2630 posts in 2880 days
#6 posted 08-01-2011 05:04 AM
I had a General saw and the re-wiring schematic was on the inside of the motor cover. As Topa said though, you won’t be able to run a 2HP saw off your current garage wiring even if you convert the saw to 110V.
View pmcwood's profile
pmcwood
11 posts in 2491 days
#7 posted 08-01-2011 06:42 PM
Those 110V / 220V dual voltage motors fail a-lot when they are converted to 110V. Usually it’s due to undersized wiring, be careful.
As many failures that I’ve seen, I usually don’t recommend changing to 110V. Especially for motors over 1-1/2 HP.
-- PMC Router Bits, http://www.pmcrouterbits.com - Hammond, Louisiana
TopamaxSurvivor
#8 posted 08-01-2011 07:27 PM
I agree with that totally. If you notice any hesitation when you turn on a motor, there are low voltage (small wire) issues that damage and shorten the motor life.
Justin
#9 posted 08-01-2011 10:33 PM
All of the above makes, which kind of makes me rethink my options. Would it hurt the saw to rewire it and use it for a month or two while we upgrage the electrical and change back to 230? It wouldn’t get a huge amount of use in those few months.
TopamaxSurvivor
#10 posted 08-02-2011 03:07 AM
Probably not if yoiu have 120 volt circuit that will get it started.. It should have a thermal overload that should trip if it overheats to much. They are usually set too high so there isn’t a lot of nuisance tripping.
Manitario
#11 posted 08-02-2011 05:25 AM
If your garage is just wired for 120V, it is probably only on 15amp breakers; your saw will draw 19.5amps when wired to 120V (more amps at startup) which will trip your breaker every time.
View Popsnsons's profile
Popsnsons
387 posts in 2979 days
#12 posted 08-02-2011 05:49 AM
You also want to consider the size wire going from the breaker to the outlet. 14awg may not carry the load, depending on the distance of the run. Haven’t done the math but trying to prevent a potential fire hazard.
-- Pops ~ In So Cal...
TopamaxSurvivor
#13 posted 08-02-2011 07:20 AM
There are some breakers out there that probably shouldn’t be. I would not say a 15 amp breaker won’t start it until you try it ;-)) Number 10 wire is the proper wire for this motor on 120 volts. It may take a 40 or 50 amp breaker to start it. Some brands, smaller may hold it just fine. If they do, you might want to consider getting a better quality panel installed.
View Moron's profile
Moron
5032 posts in 3891 days
#14 posted 08-02-2011 07:29 AM
hire an electrician
it will be the best 35 bucks you ever spent
Grandpa
#15 posted 08-02-2011 08:35 PM
Just hire and electrician and he will take care of the voltage, saw and panel. There are too many unknowns here.
Topo the way you wrote the above answer it sounds like you are advocating using 10 ga. wire and 40 amp circuit breakers. I don’t think you meant that but if Justin tries that he could get into trouble. I think you were just thinking on paper so to speak. It might take a 40 or 50 amp breaker to start the motor but you would need wiring for 50 amp breakers. Now we are into 6 ga.
