Joint two dowels - square or round tenon?
« back to Joinery forum
Forum topic by Bodgers posted 09-03-2018 02:03 PM 1333 views 0 times favorited 19 replies Add to Favorites Watch
View Bodgers's profile
Bodgers
5 posts in 139 days
09-03-2018 02:03 PM
I posted this question on a UK forum I am a member of, and there was a clear response over which was better.
My (bad) sketch shows the two options. Key point is that the two dowels are subject to rotational force. Beech is the material.
What would be stronger?
19 replies so far
View eflanders's profile
eflanders
320 posts in 2089 days
#1 posted 09-03-2018 03:24 PM
If there is rotational force between connected parts, it’s a no brainer, the square tenon. It provides the most surface area for glue and a keyed connection.
Bodgers
5 posts in 139 days
#2 posted 09-03-2018 03:35 PM
If there is rotational force between connected parts, it s a no brainer, the square tenon. It provides the most surface area for glue and a keyed connection.
- eflanders
I agree. But, the replies I got on UK workshop firmly came down against the square tenon and in favour of the round.
Interesting…
View clin's profile
clin
974 posts in 1234 days
#3 posted 09-03-2018 04:33 PM
There’s no question the square one will transmit the rotational forces even with no glue. So in that sense it is better. But if it isn’t a tight fit, the glue will be holding it. And if the glue fails it might not matter if it’s square if the pieces would separate.
Glue is also strongest in shear, and the round one the entire glue surface is in shear. The square also applies tension to the glue join, so maybe it would tend to fail more. But of course it would have more glue area.
Concerning the U.K. choice of round over square, was that because of function or perhaps related to how you would make the joint or even how you might assemble the finished item? Or maybe they know something about the application. For example that square versions tend to crack because the corners of the mortise to create stress risers.
If the rotational forces are relatively low, I think round is fine. But if it gets serious torque, square would be mechanically secure. So without knowing more, I go with square.
-- Clin
View AlaskaGuy's profile
AlaskaGuy
4994 posts in 2548 days
#4 posted 09-03-2018 04:42 PM
- eflanders
Interesting…
- Bodgers
But why????? What was their reasoning
View 000's profile
000
2859 posts in 1138 days
#5 posted 09-03-2018 04:47 PM
Furniture dowel and recess the handle into the head with glue.
Bodgers
5 posts in 139 days
#6 posted 09-03-2018 04:57 PM
The reasoning was related to what clin refers to.
Weakness at the corners and the fact that cutting the square on the end of the dowel and the mortise in the other weakens the whole thing.
One poster refers to grain direction. But I don’t see that as being any different. Unless this was the shear thing.
The application is a tail vise screw. The thicker dowel is the head end.
Nothing special about the assembly. It will just be glued (possibly with epoxy) and then clamped (if needed).
I will post the thread later.
Bodgers
5 posts in 139 days
#7 posted 09-05-2018 07:32 AM
View TravisH's profile
TravisH
641 posts in 2173 days
#8 posted 09-05-2018 11:14 AM
I have thought about this one before. We can measure all the forces at play and determine the scientific answer but if both methods work for the intended application and we don’t truly know the numbers equates to basically a bunch of woodworkers playing arm chair physicists. Interesting discussion and something I could see Mathias Waddell or other online video woodworker putting to the test. Historical use likely can be used as “best method” of construction.
Historically the pieces I have looked at, old work benches, grape presses, wheels, old wood gears, and other “vintage” wood screw applications always appear to use round mortise. I figured most of that was a function of method of making and ease of repair. Doesn’t get much quicker than drilling a hole and rounding a spoke. Now many of these pieces are hundreds of years old and have been used a few times over that time period and appear no worse from wear. I have observed several that have been pegged but very few.
View EarlS's profile
EarlS
2121 posts in 2586 days
#9 posted 09-05-2018 11:24 AM
I think I would go with a loose tenon, that is, a rectangular dowel that has had the edged rounded off. The accompanying mortise would be made using a router (see the Leigh mortise and tenon jig). The problem of sharp corners that would be week points where the stress/load would cause the wood to break would be reduced/eliminated.
View jerkylips's profile
jerkylips
483 posts in 2809 days
#10 posted 09-05-2018 02:16 PM
I would tend to think that if you’re gluing it, the shape would be somewhat irrelevant. Modern glues like Titebond are so strong, the wood will likely fail before the glue joint. In your application, I can’t imagine you’ll be stressing it that much.
View ScottM's profile
ScottM
698 posts in 2385 days
#11 posted 09-05-2018 02:25 PM
To me, the question is, how much rotational force are we talking about? In other words, will the wood stand up to that force regardless of the joinery method.
View therealSteveN's profile
therealSteveN
1903 posts in 813 days
#12 posted 09-05-2018 02:40 PM
- clin
I agree with this reasoning, and if making this joint I’d would proceed that way, but it would be nice to know what you were making. I would assume the Brits knew, and it had a low rotational force. Otherwise their answer makes no sense.
-- Think safe, be safe
View DS's profile
DS
3045 posts in 2659 days
#13 posted 09-05-2018 02:59 PM
Unless you are making them by the thousands for resale, it doesn’t really matter.
Heck, build one of each, try them out, then let US know which one was better.
My 2 cents…
Have fun.
Bodgers
5 posts in 139 days
#14 posted 09-05-2018 03:19 PM
Hard to quantify the exact forces.
This is a tail vice screw. So, if you imagine the ‘Head’/thicker end with a wooden bar going through it (which is the screw handle), this is about 250mm long, the hub being 60mm in diameter, so you have a force being applied on the end of that by my hand and arm (I don’t work out, and my arm isn’t that strong) to turn the screw that clamps a work piece.
It is possible that the wooden handle passing through the head will break first, I suppose.
View jmos's profile
jmos
905 posts in 2608 days
#15 posted 09-05-2018 04:39 PM
The square end would certainly transfer the rotational forces better, and not rely entirely on the glue for strength. The round would be easier to cut.
If it were me, I think I would go with a round mortise and tenon, and peg it with a wooden or metal pin. That would also prevent relying entirely on the glue to transfer the forces.
In this application, I don’t think I would rely just on glue. How many glued parts have we each seen fail on chairs?
-- John
