Router problem
Forum topic by sawdust99 posted 07-30-2011 08:57 PM 1009 views 0 times favorited 6 replies Add to Favorites Watch
View sawdust99's profile
sawdust99
26 posts in 2798 days
07-30-2011 08:57 PM
I need to put slots in round wood disc. I tried a regular and spiral bit in my router table. Problem is I get tear out. The slots are 3/8” wide and 1/4” deep. Any suggestions? Thanks for any help.
View acducey's profile
acducey
65 posts in 2411 days
#1 posted 07-30-2011 10:16 PM
You might try making a template for the slots, afixing it with double-faced tape to the work piece, and then, using a 1/4 inch bit, proceed to route out the slots going around each at depth of 1/8 first, and then full depth.
View fussy's profile
fussy
980 posts in 2957 days
#2 posted 07-31-2011 01:11 AM
What kind of wood? Hand held or table mount? If hand held use down-cut spiral bit, if table mount use down-cut (it’ll cut up toward the bottom of the groove) spiral. The idea is to cut away from the finish face of the groove towards the bottom. This pulls the wood fibers into the cut, shears them off and prevents tear-out. Hope that’s clear as mud.
Steve
fussy
#3 posted 07-31-2011 01:12 AM
Steve
View LONGHAIR's profile
LONGHAIR
94 posts in 3721 days
#4 posted 08-01-2011 01:21 AM
“Slots” as in concentric rings?
If so I would guess that your tear-out is coming in the areas of the grain where the bit is “lifting” the fibers. If so, there are a few ways to try to mimimize it. Shallow multiple passes can help, as can “climb cutting”, but it really depends upon the guiding method you are using.
View Don W's profile
Don W
18606 posts in 2474 days
#5 posted 08-01-2011 02:02 AM
how deep are you cutting in each pass?
fussy
#6 posted 08-03-2011 08:25 AM
cr1,
Yes, they come as up or down spiral, and up/down compression spiral bits Up cut clear the mortise, groove whatever by drawing chips out with angled flutes. This risks tearout because the cut fibers are lifted. Down cut bits compress the cut fibers down into the cut minimizing tearout but packing the cut with chips. Up-down work both ways, help minimize tearout on the surface and clearing. As with most compromises, they should be used judiciously and carefully. The up/down refers to cut direction from the end of the bit. Most suppliers -Lee Valley, MLCS, WhiteSide, etc have them and they work well.
Steve
