Sharpening turning tools
Forum topic by MedicKen posted 07-30-2011 07:52 PM 1263 views 0 times favorited 10 replies Add to Favorites Watch
View MedicKen's profile
MedicKen
1615 posts in 3459 days
07-30-2011 07:52 PM
I am just getting starting turning and have a question about sharpening the tools involved. I have a grinder that is outfitted with the Wolverine jig. I have watched the video that came with the jig and it all looks pretty straight forward, well almost. The video does a fair job of explaining the jig and how its used with fairly new chisels. My problem is the tools I have acquired are AFU. Meaning, the bevel angles are not consistent and not even close to what I have read they should be. Is there a trick to setting the angles and what have you found to be the optimum for the varying tools?
10 replies so far
16274 posts in 4216 days
#1 posted 07-30-2011 07:57 PM
I guess you could find a reference chart somewhere, but what I’ve seen from experienced turners is that there is a lot of personal preference involved.
View WayneC's profile
WayneC
13754 posts in 4094 days
#2 posted 07-30-2011 08:03 PM
Angles vary from tool to tool. I have seen some charts in wood turning books and their are videos on the topic. I have also seen jigs that are used set up the arm and varigrind positions. I linked a commercial version, but similar stuff can be shop made.
http://www.woodturnerscatalog.com/store/Sharpening___Universal_Jigs___Raptor_Set_Up_Tool___raptor?Args=
View David Kirtley's profile
David Kirtley
1286 posts in 2995 days
#3 posted 07-30-2011 08:53 PM
The angles also vary for the material you are turning. If you turn really hard stuff, they get a steeper angle. Softer stuff gets a finer angle. The way you hold the tool makes a difference as well.
The real answer it to turn with them. The bevel is the clearance angle. If you want it to cut and all you are getting is scraping or it is skipping off the cut on the bevel, try a bit finer bevel angle. If you are getting too many hangs or losing the edge too fast, you might try with a higher angle.
View mpax356's profile
mpax356
72 posts in 2489 days
#4 posted 07-30-2011 10:21 PM
For a bowl gouge I would start at 50 to 60 degrees. As you gain experience you might vary it. You might try about 40 degrees on your spindle gouge. The key to using the vari grind is understanding what you want your profile to look like. Sharpening turning tools is not intuitive. I recommend you check find a local chapter of the American Association of Woodturners. You will much more easily and safely climb that learning curve with a few hours with an experienced turner. You can find a local chapter here
http://www.woodturner.org/community/chapters/LocalChapters.asp
I see there is one in Bakersfield.
-- MPax, Atlanta
View ChesapeakeBob's profile
ChesapeakeBob
366 posts in 3480 days
#5 posted 07-31-2011 05:42 PM
MedicKen… I give up… what is “AFU?”
-- Chesapeake Bob, Southern Maryland
WayneC
#6 posted 07-31-2011 05:47 PM
Bob AFU = All (4 letter word beginning with F) Up
ChesapeakeBob
#7 posted 07-31-2011 05:51 PM
Thanks Wayne. I was not thinking of engineering terms. LOL!
WayneC
#8 posted 07-31-2011 06:00 PM
Yup. It is a very precise term used to describe a number of very specific conditions. You clearly know when it applies.
View Bluepine38's profile
Bluepine38
3379 posts in 3082 days
#9 posted 07-31-2011 07:30 PM
Unfortunately in usually applies to me with a prefix SNAFU indicating Situation Normal AFU, at least I am
serving as good bad example of do as I say not as I do. This is a term that was in general usage in the
military a few (OK more than a few) years ago.
View lcurrent's profile
lcurrent
125 posts in 3813 days
#10 posted 08-05-2011 10:01 PM
cr1 Got it nailed on the button
-- lcurrent ( It's not a mistake till you run out of wood )
