Wolverine installation help needed
Forum topic by MedicKen posted 07-30-2011 05:07 AM 1320 views 0 times favorited 2 replies Add to Favorites Watch
View MedicKen's profile
MedicKen
1615 posts in 3491 days
07-30-2011 05:07 AM
For the turners out here who own and are using a Wolverine jig I need some help. I am installing the jig under a 6” grinder WITHOUT wheel guards. The instructions state “The base must be approximately 1/2” or less from the front of the mounting board”. Are they referring to the Wolverine base or grinder base?
The directions also recommend 6 1/4”-6 1/2” from the mounting board to the centerline of the grinder shaft. Is this clearance necessary for a grinder WITHOUT guards? Directions ” This will be necessary if any part of the base interferes with the wheel guards and when using the ONEWAY Dressing Jig”, which I also purchased.
I know that using a grinder without guards is not a very safe practice but my grinder did not have any at time of purchase. I am looking for some, but they are not readily available for a Cincinnati grinder from 1955.
2 replies so far
View jimp's profile
jimp
208 posts in 3789 days
#1 posted 07-30-2011 05:50 AM
They are talking about the Wolverine base. The front Wolverine base must be in line with the front of the wheel and front of the Wolverine base must be 1/2” or less from the front of the mounting board. The front of the Wolverine base must be 1/2” or less to front of the mounting board, so the mounting board doesn’t interfere with any Wolverine attachments like the vee-arm.
I’m not sure, if you will have any issues with any of the sharpening jig, if the Wolverine base is mounted closer than the 6 1/4” to the center of the wheel. If the base in mounted closer than the 6 1/4”, you may not be able to adjust the vee-arm or platform attachments to the correct position to get the correct sharpening angles.
-- - Jim, Carroll, OH
MedicKen
#2 posted 07-30-2011 06:57 AM
Thanks Jim….I am gonna install it and see what happens. If it like everything else I do it will be together and apart 2 or 3 times anyway
