Need help deciding on a finish
Forum topic by Tenfingers58 posted 662 days ago 400 views 0 times favorited 2 replies Add to Favorites Watch
View Tenfingers58's profile
Tenfingers58
56 posts in 846 days
662 days ago
My wife wants me to build new cabinets on three walls of our sun/dining room. About 30 feet total. I asked her what she wanted them made of and got the “deer on the headlights” look. So, I made the mistake of telling her to go through my scrap bins, drums, and boxes and see if she could find anything she liked. Well after looking for almost an hour she brought a piece of waferboard that I’d run through the drum sander to see what it would look like for a craft project. It sands fairly smooth but the problem is all the depressions or voids between the pieces of wood that it’s made out of.
She really likes this stuff! The problems, as I see them is how do I fill the depressions/voids so the finish looks good. I don’t need a “piano” finish, but I would like a smooth finish I can be proud of. Also is there a stain that I can use to darken it slightly. I don’t know how well stain will work on this material with all the glue used in the manufacturing process.
I haven’t done much cabinetwork / furniturebuilding in a long time. I am very out of date on what’s available, and what’s best to use in this application.
Tomorrow I’m off to the lumberyard to get a sheet to cut up into tryout pieces to figure out how to make good looking cabinets (including raised panel doors and drawers) out of this stuff. Mainly I’m concerned on how to get a nice finish on it that will last. I figure that it will be treated no worse than a kitchen counter as far as spills and hot plates. There are also windows that sometimes get left open in the rain, so water resistance is a high priority.
I’m thinking a seal coat of 50/50 polyurethane & thinner, then second coat with 100% polyurethane. Do you think the 50/50 poly will self level enough to fill the depressions / voids. I’m open to any suggestions.
Thank you.
2 replies so far
View Tennessee's profile
Tennessee
1089 posts in 683 days
#1 posted 662 days ago
I’m assuming you are referring to OSB, or oriented strand board. This used to sometimes be called “waferboard”, but I have not heard that term in ages. I don’t think you can get all the voids out of it, IMHO. And it will take stain based on what they used. Most of it is a collection of various softwoods. They basically chop up the wood into splinters of a range of lengths. Then, it is run down a chute into a pan-like press where a layer of wood is put in, a layer of bonder, and so on. Then they apply high pressure and usually some steam to compress it into OSB. It’s main use is underlayment on roofs and floors, and the upholstered furniture industry has discovered it big time. If you’ve bought a recliner or sofa in the last year, don’t look underneath, you are likely to get mad…
Anyway, if she demands it, you might just consider something like Minwax Natural, which will darken it ever so little, but make the grain pop. And it’s kind of like plywood in finishing – no matter what you do, it’s always going to be OSB.
Good luck!
-- Paul, Tennessee, http://www.tsunamiguitars.com
View 000's profile
000
3352 posts in 785 days
#2 posted 662 days ago
OSB as the exposed material? Did I get that correct?
I have a sense that OSB will not prove to be a pleasing look after a very short while.
Maybe right after the very first she passes by a one of those ticky tacky Toll Brothers type projects and sees what they use.
As for making cabinets from the stuff: It will not work for that application.
The edges don’t hold up, you can’t cut profiles in it, It doesn’t take joinery even half as well as plywood, and it flakes. There will always be huge flakes that flake off because of glue starvation in the manufacturing process.
-- When the moderator chooses sides, his site sucks.
