MIDI Lathe Chuck Advice
« back to Woodturning forum
Forum topic by RPhillips posted 08-27-2018 12:37 AM 1022 views 0 times favorited 22 replies Add to Favorites Watch
View RPhillips's profile
RPhillips
1244 posts in 2077 days
08-27-2018 12:37 AM
I have a Jet 1221VS lathe and I really need to get a chuck. From my reading, it seems that the Nova G3 is pretty much the go to for this size of lathe and I have seen a bunch of people also suggest the SuperNova2.
Being new to turning, I don’t haven any experience with either and really have no clue as to the difference other than the G3 using a geared wrench and the SN2 using a standard allen wrench. I’m leaning towards the Super Nova 2 anniversary edition which comes with some extra jaws mainly due to it being allen keyed. The G3 is also offered in the same package, which is my second option.
Any advice on why to pick one over the other? I would like to turn some bowls in the future and mostly small boxes and tool handles.
Thanks for reading.
SuperNova2 Anniversary Bundle
Nova G3 Anniversary Bundle
-- Rob - Indianapolis IN - Learning... one mistake at a time...
22 replies so far
View DDJ's profile
DDJ
34 posts in 381 days
#1 posted 08-27-2018 01:11 AM
I just ordered anew lathe yesterday and sooner or later I’m going to upgrade my chuck situation. The SuperNova2 is high on my list.
Dave
View Hockey's profile
Hockey
147 posts in 653 days
#2 posted 08-27-2018 03:52 AM
I am partial to the Nova G3. It is not as heavy as the Super Nova 2; but, I don’t know whether that is a factor with a midi lathe. The price on the G3 is also more attractive. My G3’s are all the insert type (48202).
View LeeMills's profile
LeeMills
629 posts in 1542 days
#3 posted 08-27-2018 04:16 AM
I have both G3’s (4) and SN (3) an use the G3’s at least as much as the SN’s.
I see the SN2 you linked to states it is direct threaded for a 1.25X8, so you would need to buy a spindle adapter.
The G3 at the same place is direct threaded for 1X8.
Both have nice jaw set but I am not sure you will have much use for the 130’s with the SN2 and a 12” lathe. The 100mm are the largest I have and they have handled everything with my 16” lathe.
Your smallest spigot/tenon with the set is the 50mm or for the spigot about 1.75”.
They may have an insert style set available but then it’s about $20 more for the insert.
The G3 will handle anything your lathe can IMHO.
Also the Pin jaws with the set are very good. Spigots from about 1/4” to 1”. I use mine mostly as a pin chuck; drill a 1” hole an inch deep, slide over, expand and turn. I used the worm screw a lot before I started using the pin jaws. With the pin jaws you do not need a flat area as you do with the worm screw also. The G3 is rated for all jaws except the powergrips and the 130mm bowl.
View mel52's profile
mel52
641 posts in 506 days
#4 posted 08-27-2018 06:31 AM
I’m sure I will get a larger one sooner or later, but for now I use the G3s. I have different jaw set-ups for them and they seem to do ok for me. I don’t do anything real big and haven’t had a problem. You can get them with the 1X8, or the ones you buy the insert for.
-- MEL, Kansas
View Wildwood's profile
Wildwood
2531 posts in 2375 days
#5 posted 08-27-2018 09:16 AM
What size spindle on your jet? If buy the SB2 will need a spindle adapter if buy G3 will need threaded insert.
If shop around my find G3 direct threaded deal.
http://www.packardwoodworks.com/Merchant2/merchant.mvc?Screen=PROD&Store_Code=packard&Product_Code=113103R&Category_Code=chuck-fourjaw-nova-ng3
-- Bill
RPhillips
#6 posted 08-27-2018 11:10 AM
Thanks for all the info guys.
I was beginning to wonder if the SN2 bundle was a bit too big for a 12” lathe. I think I will go with the G3 bundle.
The next question that I can’t seem to figure out is what version do I need? The one I linked (Link fixed) in my original post says it has a 1” x 8 LH/RH thread, I have no idea if this is the correct one. I know my Jet has a 1” x 8 RH thread. Not sure how a left hand thread would even stay on.
Wildwood
#7 posted 08-27-2018 12:31 PM
View Bmezz's profile
Bmezz
47 posts in 1624 days
#8 posted 08-27-2018 01:00 PM
LH/RH refers to a special threading that allows use both on the headstock and on the outboard side. Oneway supplies adaptors that do the same thing. Pretty handy sometimes.
-- Member Valley Woodturners Ottawa. Member AAW
View MrUnix's profile
MrUnix
7114 posts in 2440 days
#9 posted 08-27-2018 05:11 PM
You might also want to also consider the PSI Barracuda2 kit... More jaw sets and less money.
Hockey
#10 posted 08-27-2018 05:22 PM
I’m too lazy to change jaws. That is why I have a G3 for every jaw set I use.
View lew's profile
lew
12512 posts in 3996 days
#11 posted 08-27-2018 09:23 PM
Easy Wood Chuck. A little more expensive but made in the USA and definitely the way to go!
View OSU55's profile (online now)
OSU55
2033 posts in 2230 days
#12 posted 08-27-2018 09:49 PM
2nd the Barracuda2 chuck and jaws. Compare $ of other brands including all the jaw sets, and the 2 chucks I have work very well – you can look through my projects on LJs – all were turned with those chucks.
RPhillips
#13 posted 09-09-2018 02:37 AM
Finally got my chuck ordered this evening. I ended up going with the SUPERNOVA 2, got a good deal on a set with 4 sets of jaws and a square chuck spur.
Now I need to find an adapter insert that fits my lathe. Teknatools say I need the IRNS version, but I can’t seem to find it any where. A 1” 8TPI will fit, but I need one with a set screw for the reverse function to be used.
mel52
#14 posted 09-09-2018 02:54 AM
There are some companies that have the insert you need with a set screw type. I just can’t remember where I saw it. But they are out there.
Just checked : Woodcraft has them and I saw some on Amazon.
-- MEL, Kansas
View Nubsnstubs's profile
Nubsnstubs
1435 posts in 1971 days
#15 posted 09-09-2018 04:43 AM
According to the box my insert came in , the codes listed on the side show that for 1”x8TPI UNC RH, The code is IDNS…........ Look it up. You could also get one with the code ITNS which would be both right and left handed threads. Also, the box has a caution “Do Not Operate lathe in Reverse mode without insert set screw (Grub Screw) fully fastened.” Looks like what you are looking for is here…............ Jerry (in Tucson)
