Knots and Blades
Forum topic by DaveH posted 04-03-2008 03:09 PM 1474 views 0 times favorited 9 replies Add to Favorites Watch
View DaveH's profile
400 posts in 3709 days
04-03-2008 03:09 PM
Topic tags/keywords: knots blades sharp jointer planner
How has your experience been with jointer and planner blades hitting knots in Douglas Fir on Yellow Pine? Do the blades get nicked? Go dull a lot faster? I have some project that 2×4’s would be a great solution for. I’m just wondering how much damage I’ll do to my equipment.
-- DaveH - Boise, Idaho - “How hard can it be? It's only wood!”
9 replies so far
View Dadoo's profile
1789 posts in 3921 days
#1 posted 04-03-2008 03:53 PM
I haven’t had any problem planing pine with the exception of some occasional tearout in the area of the knots. What really has caused trouble is this 100+ year old reclaimed maple flooring I have. That stuff is so hard it’s dulling the planer blades!
View Peter Oxley's profile
Peter Oxley
1426 posts in 3805 days
#2 posted 04-03-2008 04:05 PM
I’ve run a bit of DF through the jointer and planer. I think the knots are probably not as hard as most hardwoods. The issue I have is that Fir and Pine tend to be pretty full of pitch, especially studs which are often sold pretty green. The pitch builds up on the blades which makes them behave as if they were dull. But clean them off and they’re ready to go again.
View ChasHutch's profile
56 posts in 3646 days
#3 posted 04-03-2008 06:09 PM
I just used my jointer to flatten and square 24 yellow pine 2×4s. Seemed to work as expected. The boards are flat, which was the goal.
-- Hutch - North Dallas, Tx - Safety First
View rikkor's profile
11295 posts in 3805 days
#4 posted 04-03-2008 10:28 PM
I have not had a problem with occasional knots. I don’t know if a lot of knots would make a difference.
View motthunter's profile
2142 posts in 3729 days
#5 posted 04-03-2008 10:42 PM
never seen damage from it and I have done it often.
-- making sawdust....
27251 posts in 3752 days
#6 posted 04-03-2008 11:11 PM
I haven’t had any problems either. I have run 2×4 studs though to make cauls and other shop pieces. As Dadoo said the knots can lead to tearout in the wood.
View Thos. Angle's profile
Thos. Angle
4445 posts in 3893 days
#7 posted 04-04-2008 01:07 AM
I’ve run a lot of knotty Alder with no problems. Never noticed a problem with Pine or Doug Fir.
View GaryK's profile
10262 posts in 3919 days
#8 posted 04-04-2008 07:40 AM
I would think that the knots being basically end grain would for sure dull the blade to some degree.
View 8iowa's profile
1569 posts in 3692 days
#9 posted 04-04-2008 03:52 PM
I have little difficulty with knots in pine, unless they are loose! That gets exciting!
Not all planers are the same. Some are best at “hoging down” hundreds of board feet of wood for production requirements, and others are designed to produce a fine finish at the individual project level. My planer can be slowed down to a feed rate of only 7 ft. per minute, and I can sharpen the blades myself to the point where they can shave off the hairs on the back of your hand.
Use sharp knives, light cuts and a low feed rate.
