Craftsman 36" Belt Sander/6" Disc Sander
Forum topic by MLK posted 07-26-2011 05:34 AM 1615 views 0 times favorited 4 replies Add to Favorites Watch
View MLK's profile
MLK
78 posts in 3775 days
07-26-2011 05:34 AM
Today I purchased Craftsman 36” Belt and 6” Disc Sander. When I took it out of the box and started to assemble it the first thing I ran into was a striped screw, on closer inspection I found all the guards and miter gauge were made out of plastic. So I put it back in the box and was going to bring tomorrow, Ok then I thought maybe I’m expecting too much for $149.00. So I thought I would check to see if any of you have one of these sanders and if so what you think of it.
View MLK's profile
MLK
#1 posted 07-26-2011 11:53 PM
cr1 thanks, I took back today. I stopped at Loews and they had a Porter Cable 8” disc 36” belt for $179.00 les 5% haven’t taken it out of the box yet. The only think I worry about is stopping while sanding because it’s only a 5 amp motor that translate to about 1/3 horse power
View Jim Jakosh's profile
Jim Jakosh
20284 posts in 3070 days
#2 posted 07-27-2011 05:11 AM
Plastic guards are okay but not miter gauges. It is good that you bought a Porter Cable sander. If you don’t hog off a lot, a 1/3hp ought to work out fine. I think that is what is on the one I made using a 4×36 belt. I can stall it if I really bear down an piece of wood but it cuts so good, I don’t need to do that. I just take it gradually. I have to add more crown to my top roller because the belt drifts a lot and I have to do a lot of adjusting. I think adding nylock nuts to the adjusters might help too. If they vibrate and move, that will cause the belt to wander.
That belt sander is invaluable in my shop especially for curve work. I use it all the time.
Enjoy your new tool!!!!!!...................Jim
View Delta356's profile
Delta356
463 posts in 2818 days
#3 posted 07-27-2011 05:27 AM
Porter Cable makes great tools. I have seen that one at Lowes, and it has all metal which is nice….
I find a 3/4 to 1 hp motor is best for sanders.
Sears tools are junk know, they are made so cheap, and they have way to much plastic on them.
I’m sticking with Delta Machinery, They make there machines with Metal, like a machine should be made out of.
Thanks, Michael Frey
Portland, OR’
FREY WOODWORKING INC.
View MLK's profile
MLK
#4 posted 07-27-2011 06:17 AM
I got the Porter Cable out of the box; it took about 10 min. to get it running. The belt adjusted just mine I used it for about an hour the belt stayed adjusted so far so good.
