| Forum topic by restowood | posted 1877 days ago | 3263 views | 0 times favorited | 6 replies | ![]() |
1877 days ago |
Throughout my looking at different peoples work I see some gorgeous bookmatching. I think this makes wonderful looking pieces. My question is how do you bookmatch. I have thought that you would have to resaw the lumber to thin 1/16th or 1/8” almost like a veneer. Is this correct or is there some other process to do this. Thanks in advance -- "Nature provides us with the most beautiful things in this world" |
#1 posted 1877 days ago |
sometimes I look at both sides of a board and can see that the center will look nice. I then just run it thru the table saw on edge, leaning against the fence, raising the blade in increments until it is cut down the middle. welcome to lumberjocks ! -- keeping myself entertained |
#2 posted 1877 days ago |
Resawing, and keeping the pieces in sequence, is the way to get bookmaching. You can place a “V” or some other mark on one edge of the board, to help keep all the resawn pieces in the proper order. You always start by jointing one face and one edge, to have good reference against the fence, and on the table of the band saw. Keep good pressure on the workpiece, to ensure the most even thickness; and make sure to compensate for blade drift. Most people will use a band saw, to maximize recovery from the resawing. I normally aim for thickness between 1/8” and 1/16”; at this thickness the resawn pieces are easiest to handle, and also allow for runs through the drum sander, to remove any blade marks and to prepare the pieces for glue-up, as your best bookmatching requires identical thickness for each of the halves. I have written about resawing on the bandsaw; you might want to read these posts on my blog -- Al Navas, Country Club, MO, http://sandal-woodsblog.com |
#3 posted 1876 days ago |
You can also just take any board and resaw it. The thickness doesn’t matter. I’ve done bookmatching -- Gary - Never pass up the opportunity to make a mistake look like you planned it that way - Tyler, TX |
#4 posted 1866 days ago |
I sell bookmatched full demension lumber…no resawing required. -- Wonderful new things are coming! - God |
#5 posted 1866 days ago |
What dirtclod said. I mill my own lumber and bookmatch most of it and keep it organized that way. No veneer. |
#6 posted 1866 days ago |
You can bookmatch in any thickness you’d like Restowood. In the first photo is a pic of a walnut burl that was sawn to 3/8” and was finished to 1/4”.
The next one is a bookmatched cherry burl piece. It’s currently cut 1” thick and when I find a use for it I will probably cut it to 1/2” thick each side and have 2 sets from these pieces.
-- Allen, Milwaukee, WI |
| Forum | Topics |
Woodworking Skill Share
8795 |
Woodturning
224 |
Woodcarving
28 |
Scrollsawing
61 |
Joinery
82 |
Finishing
1534 |
3553 |
15801 |
Hand Tools
2038 |
Jigs & Fixtures
495 |
Wood & Lumber
2843 |
809 |
Focus on the Workspace
903 |
766 |
Woodworking Trade & Swap
2740 |
LumberJocks.com Site Feedback
1547 |
Coffee Lounge
6162 |
