Need help with rarge radius moulding.
Forum topic by Tom Adamski posted 04-03-2008 04:57 AM 4233 views 0 times favorited 22 replies Add to Favorites Watch
View Tom Adamski's profile
Tom Adamski
306 posts in 3647 days
04-03-2008 04:57 AM
Topic tags/keywords: moulding help mantel question router milling
Large Radius Moulding
I’m having an issue. I’m making mantels for a local fireplace shop and one of their more popular mantels has a large radius face (approx 6” radius). I need to find a better way (read: easier and faster) to make this. Currently I’m taking a 2×6 board and faceting it on the tablesaw and then using a flexable course sanding form to smooth out the ridges and round the profile. This is taking forever on a 6 foot long board. The picture is a profile. The finished dimensions are 5 1/2” tall and approx 1 1/4” thick with a 6” radius curve and 3/4×1/2 rabbits on the the back. Any help would be appreciated.
FYI I don’t have a shaper…
Thanks,
Tom
-- Anybody can become a woodworker, but only a Craftsman can hide his mistakes.
22 replies so far
Douglas Bordner
4021 posts in 3940 days
#1 posted 04-03-2008 05:18 AM
I’m not sure if this would be helpful, especially at the price of $400 but would the Lonnie Bird CMT Crown molding set do what you need? It’s a tablesaw/router set of cutters.
At the least this will bump your post back up top.
View John Ormsby's profile
John Ormsby
1283 posts in 3613 days
#2 posted 04-03-2008 06:26 AM
I think you might want to think seriously about getting a shaper or molder if you are going to do a lot of these or other molding in the future. They are the 2 machines of choice because they are easier and much safer. The molder would be first choice. A basic Williams & Hussey or a Shop Fox would do just fine. You could do it on a shaper if you have a 3” or taller molding cutter head. Since the profile is symmetrical, just have a set of knives made up at 1/2 the profile and run the board through again after flipping it over. A shaper will cost much more than a smaller molding machine and a power feeder would be recommended with this type of process. I have also done, and still do occasionally, molding the way you are doing. It all depends on the amount that needs to be done and how safe it will be.
John
-- Oldworld, Fair Oaks, Ca
Tom Adamski
#3 posted 04-03-2008 06:27 AM
Doug,
Thanks for the reply, but that will cut a cove. I need a convex front, not a concave. Essentially the opposite of what that cutter will do.
Tom
View GaryK's profile
GaryK
10262 posts in 3865 days
#4 posted 04-03-2008 06:31 AM
Just make a template and then use a router with a template bit to make them all day.
Once you have a square edge you can use whatever router bit profile you want.
Use a router attached to a circle cutting jig (a long 6 foot one) with a pivot at one end and the router
at the other to make a perfect radius template.
Tom Adamski
#5 posted 04-03-2008 06:41 AM
John,
That seems to be the best solution, but at $2k for the machine and another $300 for the knives is a little rich for my wallet…
Gary,
I’m not sure what you mean… This is 6’ long. The picture is a cross section of the moulding.
Tom
GaryK
#6 posted 04-03-2008 06:43 AM
Sorry, I thought it was an overhead view. Let me think about it.
You could spend some money and get a Legacy mill. You could probably make 4 at once after you
make a jig.
Once you have one you can do all kinds of things.
http://www.legacywoodworking.com/
View hobbylogger's profile
hobbylogger
21 posts in 3589 days
#7 posted 04-03-2008 07:10 AM
wether your table saw has left or right tilt would determine what side that your rip fence would go. First determine the angle , then set your blade accordingly. run several pieces on edge at that angle, then reset the angle and the fence and run them again. This would give you a rough radius, then smooth it with a home made cabinet scraper that matches the profile, or use an orbital sander stating with 60 grt and then progressing to finer grts. I you are doing alot of these then do the steps in a production line style by doing several pieces at one time. I Hope this helped, or spured some ideas. Good luck.
-- Daniel, Tumwater, Wa U.S.A.
Tom Adamski
#8 posted 04-03-2008 07:25 AM
Thanks guys, I think I found my answer… I found a passage in “The best tips from 25 years of Fine Woodworking” on a router trammel jig that will cut the radius. Now I just have to get the book from the library and build the jig.
3809 posts in 3898 days
#9 posted 04-03-2008 07:27 AM
If you build a “bridge” of the same radius as you need for the surface that will mount your router and a set of guides to hold the board in position you should be able to run the router over the board from one end to the other in a series of passes.
By moving your router to a new postion on the Bridge and locking it you should be able to rough the piece out in about 6 or 8 passes.
I bit of sanding should join the passes quickly.
Not ideal but cheap.
Tom Adamski
#10 posted 04-03-2008 07:29 AM
Thanks Bob,
I think you are saying the same as the drawing I found. I appreciate the help. I update after I get the drawings from the library and make the jig.
Tom
View Thos. Angle's profile
Thos. Angle
4445 posts in 3839 days
#11 posted 04-03-2008 01:32 PM
My hardwood supplier has a molding business with lots of molding knives. I had him make a custom knife for my mirror moldings. He didn’t even charge me for it. If you can find one of these outfits in your area it is the way to go. I just pick the boards and then pick them up when the moldings are ready. They even have a string sander. Many of the finish carpenters and contractors use this service. These are some beautiful moldings.
View Peter Oxley's profile
Peter Oxley
1426 posts in 3751 days
#12 posted 04-03-2008 03:28 PM
You might be able to find someone with a small molding machine near you by contacting a manufacturer of molding machines. I think Woodmaster keeps a database of their customers and makes referrals.
-- http://www.peteroxley.com/woodworking -- http://north40studios.etsy.com --
Tom Adamski
#13 posted 04-03-2008 04:35 PM
Thos. & Peter… Thanks for the ideas.
View jm82435's profile
jm82435
1285 posts in 3618 days
#14 posted 04-03-2008 11:14 PM
If you had to run very much of this, a molder would obviously be the ticket. I bought an old Belsaw planer/ molder that was cheap and would make short work of this (after ~$80 for the custom ground knife). It might be worth keeping an eye out for a cheap used one. Or like was suggested earlier, find someone with a molder. In my opinion by the time you built the jig you could have paid for the custom ground knife… my $.02
-- A thing of beauty is a joy forever...
Tom Adamski
#15 posted 04-04-2008 06:37 AM
I had a little free time today, so I wanted to try to make a router trammel for cutting this moulding. It is a "proof of concept" and it is in progress. I still need to mount it to a base to keep the main arcs in alignment. I'll follow up once I try it out.
Tom
