Forstner Bit WithOUT Pilot or Spur Center
Forum topic by AaronSKuehn posted 07-25-2011 04:03 AM 13888 views 0 times favorited 35 replies Add to Favorites Watch
View AaronSKuehn's profile
AaronSKuehn
345 posts in 2522 days
07-25-2011 04:03 AM
Topic tags/keywords: forstner circle hole question drill press
Does anyone know if someone makes a Forstner bit that does NOT have a pilot or spur center?
I’d like to drill a clean, flat-bottom hole without that divot in the center where the pilot point was.
~Aaron
-- Aaron
35 replies so far
View Bertha's profile
Bertha
13528 posts in 2692 days
#1 posted 07-25-2011 04:29 AM
You could chuck a router bit maybe. You could buy a cheap Forstner and grind the point off.
View bigike's profile
bigike
4052 posts in 3287 days
#2 posted 07-25-2011 04:37 AM
i have to go with bertha
View WayneC's profile
WayneC
13754 posts in 4096 days
#3 posted 07-25-2011 04:39 AM
What size hole? I was thinking plunge router as well.
View Sawkerf's profile
Sawkerf
1730 posts in 3067 days
#4 posted 07-25-2011 06:08 AM
I don’t think that I would want to use a Forsner bit (or spade bit, hole saw, etc) without a center spur. That’s what keeps the thing from trying to skate all over the place when it’s turning.
Just for giggles, try using a hole saw without the drill bit.
View David Grimes's profile
David Grimes
2078 posts in 2638 days
#5 posted 07-25-2011 06:15 AM
I’m pretty sure there aren’t any forstners made without the center spur.
Start the hole with the “normal” Forstner, then grind the point off to finish it.
-- If you're going to stir the pot, think BIG spoon or SMALL boat paddle. David Grimes, Georgia
TopamaxSurvivor
18271 posts in 3675 days
#6 posted 07-25-2011 08:01 AM
That is what I would do; get it started, then take the point off.
WayneC
#7 posted 07-25-2011 08:05 AM
Set up two bits? I guessing there is more than one hole to drill.
10395 posts in 3647 days
#8 posted 07-25-2011 08:53 AM
The spur has a function; there for a reason.
View HorizontalMike's profile
HorizontalMike
7757 posts in 2913 days
#9 posted 07-25-2011 02:26 PM
Use two bits the same size, one WITH the spur, one WITHOUT. Start your hole with the spur-bit to get the outer portion of the bit below the surface and then switch to the de-spurred bit to finish. You did not say how deep your intended hole is so this may or may not work for you.
View TheWoodNerd's profile
TheWoodNerd
291 posts in 3190 days
#10 posted 07-25-2011 02:57 PM
Bertha
#11 posted 07-25-2011 02:59 PM
Thanks Woodnerd, I’d never heard of those!
HorizontalMike
#12 posted 07-25-2011 03:19 PM
The Nerd dun good! Cool!
Bookmarking the link as I type…
View tyskkvinna's profile
tyskkvinna
1310 posts in 2985 days
#13 posted 07-25-2011 03:39 PM
I’ve a small set of forstner bits that I simply grinded the bit off. You don’t have to pre-drill it—just use a drill press and make sure your work item is clamped or otherwise secured down and it’ll be fine. Go slow for the first couple of rotations to make a groove, then crank it up fast and hold on tight.
those flat-on-purpose bits look really cool!
-- Lis - Michigan - http://www.missmooseart.com - https://www.etsy.com/people/lisbokt
TopamaxSurvivor
#14 posted 07-25-2011 06:08 PM
That looks just like mine so I wondered what the big deal was?? Googling Forstner bits http://www.google.com/search?rlz=1T4ADRA_enUS423US423&q=Forstner+Bits&um=1&ie=UTF-8&tbm=isch&source=og&sa=N&hl=en&tab=wi&biw=1024&bih=515
was a bit of a surprise. I didn’t know they come in such a wide variety.
David Grimes
#15 posted 07-25-2011 06:14 PM
I bet the rim-guided are not best sellers at $45 a pop.
How about start ALL the holes, then grind the spur to finish (and still need only one) ?
OP says “a… hole…” so maybe he only needs to do one, anyway.
showing 1 through 15 of 35 replies
